They were the OEM.Were they the OEM bulbs or did you have the H4 upgrades in there when you put in the LEDs?
They were the OEM.
My G6 LED were a huge improvement over 55/60W halogens that were a huge improvement over 45/45W halogens. Going straight from factory to good LEDs is huge but I wouldn't have truly appreciated the difference between the G6s and 55/60W bulbs without experiencing it.A huge improvement then.
For an ST1300 – no. It's not needed nor recommended at all. For an ST1100 it is needed and therefore is recommended unless it's one of the rare LED bulbs that comes from the manufacturer with the proper tab placement already in place.is an adapter ring necessary when using these bulbs with the tabs snipped off?
But for the brain addled among us, is an adapter ring necessary when using these bulbs with the tabs snipped off? My head is spinning with every other message mentioning "just snip the tabs" followed a few posts later "but you must have an adapter" or "a piece of wire" to keep the modified bulb from falling into the shell.
Which is it?
Looking at mine, only the low-beam (shielded) chip is.The Led bulbs have the chips on the centerline of the bulb.
Yes, I did all mine at the same time. I do prefer the looks. I feel I can be seen better as well.
I never did take a "before" photo with the stock headlight and orange markers turned on. Closest I have is lights on (halogen headlights, peanuts and orange running/direction signal and one clear lens & white/orange switchback LED installed.
No. Do them both.I have a burned out headlamp, thinking about this upgrade, would it make any sense to replace only one side with an F2 LED? Thanks for input.
Well, at the very minimum, it would look rather strange.I have a burned out headlamp, thinking about this upgrade, would it make any sense to replace only one side with an F2 LED? Thanks for input.
Not so.You'll have to pull some tupperware to install one anyway.
Fair enough. Let's just say for me, tupperware removal was the only way I would be able to install to my satisfaction. Plus I was going for a full LED upgrade and it made getting to the marker lights a whole lot easier (at least the dash removal).Not so.
<snip!>
No question in my mind- replace both.
Hum... About ready to make this upgrade too for my ST1100.
So, the same led light can be used in the ST1100 and ST1300. The only difference, is the way we have to adapt it to the "socket", if I can say.
I already have ordered (and received) the 2 adapter ring for my ST1100.
I will now order these Katana H4 9003 ( from spiderman302 link ), from Amazon, since they are shipped from the US and therefore, should arrive a bit faster than those on ebay from china.
A little while ago someone posted on this forum that the ones in the below link are the same F2 bulbs but from Amazon Canada, so CDN dollars and free CDN shipping.See if you can find a Canuckian seller (or shipped by Amazon.ca) Some of that cross border stuff is being held up right now. Waiting over a month for brake lines that were shipped USPS from Ohio.... Hopefully your experience will differ!
