pdfruth
P.D.Fruth
Re: My home-built DIY gear position indicator - includes plans
Actually, I did install it inside the display enclosure. See photo's below. With my display velcro'd to the base of ST's handle bars (as pictured in my opening post), the sensor is facing straight back and slightly downward. My testing in the garage/driveway works well with this configuration. I've trained it such that;
- With the bike sitting in the garage (nose first), and the garage door open, the display shines brightly.
- With the bike sitting in the garage (nose first), and the garage door closed, the display adjusts itself, and shines dimly. Note: My garage door has one row/panel with windows, so it lets some light in, but it gets dark enough for the light sensor to pick up the fact that it's darker.
- With the bike sitting out on the driveway, in bright diffused light (i.e. mostly overcast), the display shines brightly.
- With the bike sitting out on the driveway, about 30 minutes after sun down, the display adjusts itself, and shines dimly.
So I'm encouraged by my tests with the photo-cell actually inside the display enclosure, in its current orientation. I just gotta get out and do some real-world test rides at dusk. Who knows, its spossed to get up near 60 degrees here on Saturday. Maybe I'll get an opportunity sooner than I thought.
BTW, on my RC51, I have the same setup. But the display is oriented such that the top of the display (where the photo-cell is) points straight up, thru the wind screen. A most ideal situation
The choices are endless. The options are limited only by imagination.
The photo-cell I'm using is small enough to be slipped into the empty barrel of an Bic pen. If my testing with the sensor in its current location doesn't work, I may do what the car manufactures do.... drill a small hole in the top of the dash, then glue the Bic pen barrel in with an 1/8 inch of the tip sticking out.
So, the photo-cell is not installed in the seven-segment display box. I assume it *could* be, if the box had a clear plastic section on the lid.
Otherwise, the photo-cell could prolly be mounted inside it's own weather-proof (clear-lidded) box/housing (somewhere out in the open). This second box would also be an ideal place for the learn button, for one-handed teaching - one finger for the button, and the rest of the hand to shade the photo-cell (as desired).
Or thirdly, you could put the display and the photo-cell in the gauge-cluster like the other fellow did in the earlier photo(s). But then there's the learn button to add somewhere. Oh, the choices :?:
