Ok, my final thoughts on a GPI install using the DiGi purchased off eBay for about $25.
I followed the instructions included with the DiGi and combined them with the install instructions found on the last page of this thread.
As I mentioned before, I used a yellow 6' cat 5 network cable that I had laying around, cut the ends off connected them to the DiGi.
for a switch to program it I purchased a $5 switch at Home Depot (GSW-41 Rocker Switch). (any 110/120v switch will work on 12v, just don't try to go the other way)
I soldered the wires together and covered it with a bit of shrink wrap. I am going to let the program switch hang out in the glove box for now.
I suggest getting your Speedometer pulse, power and ground off the left side of the bike under the mid fairing.
Getting them from the right side is a real pain. The wires are easier to identify, but there is so much more work involved. See the picture with my dirty hand pulling back the rubber cover so you can see the yellowish cover where the speedometer pulse, power and ground are available. Its really only accessable after removing the charcoal can and the tip over bar that are in front of it.
The instructions call for a Tachometer Pulse, this is the Ignition pulse found under the seat on the right side of the bike.
The programming was quick and simple, took less than 1 minute with my bike on the center stand.
I currently have it mounted on the dash on the left side, once I am sure where I want it the additional surgery can be done later.
I am thinking it will probably go inside the dash in the bottom right corner of the speedometer in that blank space.
