Article [13] ST1300 - Fuel Pump Replacement
Thanks a bunch!
But how does draining the lower tank from the hose connection #6 on the top of the lower tank drain the gas out of it?
The gas gets siphoned out as long as the hose that you put in to your catch-can is kept below the level of the bottom of the lower tank.
I just got through doing this. Pull the fuel return hose. (The one with the clip) Attach you siphon hose to this and suck. (I got a cheap siphon from Harbor Freight and it worked great.) The return line goes to the bottom of the tank and you can just about get it sucked dry this way.
