It already has a drinking problem...I just hope this one doesn't pick up that nasty smoking habit ...
Amazing! If it was me, I'd still be removing body parts.If all goes as planned, I'll take her out for a little 'road run' tomorrow since she is all back together now.
I hate that feeling when I'm cleaning up after such an effort and find a crucial part left over that I should have installed in 'step 2'.Well, it depends if I can get enough 'road miles' on it between now and then to make sure I didn't miss something.
This would be me as well. Maybe a stupid question, but when you’re putting a new engine in, do you do all the rehab for it (new hoses, new timing belt, etc.) before installing it? Best of. Luck on the test run!Amazing! If it was me, I'd still be removing body parts.
Nope, not on an engine with 23,000 miles.This would be me as well. Maybe a stupid question, but when you’re putting a new engine in, do you do all the rehab for it (new hoses, new timing belt, etc.) before installing it? Best of. Luck on the test run!
Wouldn't find such on today's products....- they are thankfully way overengineered for the job.
Is this bike's nickname "Christine" by chance?Well the engine runs fine and pulls properly, but now an 'old' problem is back -
(8) ST1100 Cooling System Problem | ST1100 Related | Page 3 | ST-Owners.com
corrected that for you...Is this bike's nickname "ChriSTine" by chance?
Which ground - the 'main' ground for the bike (the battery cable) or a wire on the gauge?OK so here is a wierd one I just ran into with the temp gauge. I chased down a loose ground in the spring that was maiking my gauge act weird. That fixed it. Then just beofre WiStoc I was doing some maintenance had taken the ground bolt off, I don't remeber why btw. Anyways when I put it back together my gauge started acting weird doing the same thing running at 12 O'Clock or more. Instantly when the fan finally kicked on just below the hot line the fan kicked on and temp spiked. Yes once it got hot it would not cool down either. I got home and started looking for a loose ground but found nothing. So I am thinking basic wiring stupid! Then I think metal frame touching metal on the ground wire, then rubber bushing for bolt to go through. Metal, Metal, Insulator (that rubber bushing). So I added a washer so the ground wire was sandwiched between metal. that instantly fixed it.
Nope, but I may change her name to 'Engine Eater' ....Is this bike's nickname "Christine" by chance?
Methinks he refers to the (one) mains-ground wire attached near the grab-handle bracket (LHS on frame, above fuse box)I don't know what 'rubber bushing' you are talking about.
