RobbieAG
Robert
I also have a 55 mile commute and was very pleased when I got 49 mpg recently (I also recorded 52 another time but not on commute). That's about 5 mpg better than I usually get with my 750!
I ran a few months on 93 octane (blue dots) to see if I saw a difference in MPG. No significant difference observed, and none was really expected on a carbureted engine.
Octane requirement is a function of engine compression ratio, why would it matter if it were carbureted or fuel injected?
IMHO, there are a lot of good suggestions above.
Does the rear and front wheel spin easily on the center stand and with the front wheel raised ?
Also, you could run some carb cleaner with the next few tanks of gas.
Try some non-ethanol gas and see if that improves your mileage.
It's also a function of spark timing. On FI engines (with computers), timing can be automatically advanced without knocking using a higher octane, which generally gets you more efficiency at higher RPM's. Carb'd engines generally have a fixed timing range that is independent of octane and knocking.
At least that's how I understand it.
I've always assumed that the higher efficiency of advancing the timing to the edge of knock outweighed other variables but that certainly may be wrong.
I guess I've always assumed that the engine advance curves were already setup to optimize performance for general street use, and that the fuel grade was used as your 'knock sensor' to operate at maximum advance without knocking, but I don't know for sure either. I have no idea if any power gain was available simply due to additional timing advance by being able to operate right at the threshold of knocking, so I wouldn't try to argue that point either way.
I suspect the main power gains have been the result of better airflow through the cylinders, ...
