Uncle Phil
Well, I took her for a short road test (with all of the body work stripped off) just to see how she stopped in the 'real world'. No problem at coming to an 'orderly' stop from 70 mph (of course I tested at lower speeds first
). Quite an improvement from the standard 'stoppers' which was what I was hoping for. If I really got serious, the nose would squat with a decent squeeze of the lever. I wasn't about to grab a handful as I am pretty sure the front would have locked up. So the ABSII brakes on a standard ST1100 can be done with all ST1100 parts (except for a three way junction) but it ain't a job for the faint hearted or easily discouraged. It does require having the entire hydraulic ABSII system as I used hoses, lines and brackets from other parts of the system to get the lengths needed. I did have to 'rebend' one steel line to get the curves right for the front and used an after market three-way junction (the only non-ST1100 part) to connected the front lines from each side and the master cylinder. On the back, I used the double ABSII banjo bolt so I could run both lines to the master cylinder. I'll post some pictures when I get the chance.
