Look at post 35 the last line.
That's why I deleted my post about the seals …Look at post 35 the last line.
That's what she said! (just not about me!)Uncle Phil said:If I just had a hose stretcher ….
It can be hard to get fluid everywhere it needs to be without bubbles.The 'grand junction' is at the bottom of the triple tree fastened to the lower fairing stay 'prop' bolt. The 'hookups' are the normal ABSII hookups (hose and metal connector pipe) for each caliper connection. I'm getting some fluid out of all of the bleeders but still a lot of air (tiny bubbles like the fizz on a Coke) and no resistance on the lever. I'll try the open/close method with the 'longest hose' bleeder and see what happens. Probably just going to be a bazillion more squeezes of the lever.
Quarter turn should be plenty if there are no obstructions.1. How far should the bleeding nipple be open - a quarter of a turn (trying to avoid sucking air through the threads)?
Assuming that you are pressure bleeding, as opposed to vacuum bleeding, anything downstream of the bleeder nipple doesn't matter, what counts is what is coming out of the bleeder nipple. However, if you have bubbles between the bleeder and the check valve they can only be coming from the brake system as the pressurized brake fluid will force fluid out through the bleeder threads rather than allow air to be sucked in. This assumes that your tubing fits tightly around the bleeder nipple and air is not being drawn in there.2. With the 'speed bleeders' - one-way valve with clear hoses on each end, should it be solid fluid all the way to the valve or just as long as it is solid coming out of the nipple?
Might be an air bubble in the master cylinder. Try bleeding the master cylinder first. Rotate the bars so the banjo fitting on the master cylinder is at the highest point that you can get it. Bleed the master by using the same pressure technique as is used on the caliper bleeders by opening the banjo fitting on the master cylinder when the fluid is under pressure. Once all of the air has been expelled from the master cylinder bleed the brakes again.But I don't get the amount of 'lever resistance' ......
Based on the lever not pumping up, I’d say there is no air. This is the feel of, the amount of lever travel for, pumping 6 pistons instead of 4.I have 'beat' and 'whacked' calipers and lines until my beater and whacker are wore out!
I cracked the banjo at the master cylinder, and all I get is fluid, no apparent air.
The lever does not seem to 'pump up' any noticeable amount.
AFAICT, the front wheel stops quickly with a half squeeze on the lever but you can continue to pull the lever to the grip.
Still going from bleeding nipple to nipple to check for air.
There are a few bubbles in one line but I'm beginning to think it is from opening the nipple too far.
A fact to consider - the center pistons and their chamber are much smaller than the primary outside pistons and their chamber.
Ah, tommorrow is another day, Scarlett!
