Gasket kit is cheap enough that its probably cheaper than OEM Honda for just the valve covers, etc. But its cheap chinese and you get what you pay for.
Leave the engine alone. Period. No reason to go into it. The failure rate is approaching zero and you have more chance of doing damage than something positive.
Take a look at the timing belt. If it doesn't look dry rotted, teeth cracked, etc. I'd leave it be. There are essentially zero failures of these belts, at any mileage and age. Most do them at 100K and state the old and new belts looked the same.
I probably shouldn't admit it but mine has 80K, purchased with 41K and I have never checked the valves. Maybe it was done by the previous owner, maybe not. Again, when most check valve clearances they are in spec. I've also never rebuilt the carbs or even synched them. The bike runs great, starts perfectly, no bad noises, gets 47mpg and is dead reliable.
They are very well engineered machines that need very little maintenance. Coolant system/hoses/tstat, check the drive splines and replace the 3 orings when you do new tires, go through the calipers and refresh with a kit from Brakecrafters, engine oil, fork oil and then go ride the thing.
