I Finally installed mine, quick, easy ten minutes. They look great and feel great, but as stated above will not start unless it's in the third setting.
What handle bars do you have on that bike?
The thing is that I don't know which are compatible with ST1100...If you look on their website, I'm sure you'll find compatible ones for the 1100.
Otherwise, do the levers match from 1300 to 1100?
i called a few distributors last year and they all said- "we don't have levers for ST1100. Only for 1300".Good luck with that. As you've found out there is no application listed for the 1100.
Maybe somebody will answer that for you. You could also try emailing the seller and see if they know.
I have the levers in all black and like them a lot. But be advised if you adjust the clutch lever to pull it in too far/much before disengaging, it won't depress the clutch interlock button. When this happens you can't start the bike in gear. You have to shift to neutral or spin the adjust back to a less "aggressive" number.
I think "2" or "3" was the most I could select and get the most reliable functioning. If you never need to start the bike in gear more power to you and the axle and you can dial in whatever adjustment you want. You might also want to get a very small Allen wrench/hex key and tighten up the pivot points in the levers.
HI all,
can someone tell me if these levers from 2wheel are the same length as stock? I can find anywhere that has measurements of them. Only that the shorties are 1 1/4" shorter than the longs. . . I think that I want the shorties, but I need to know the length of the longs in order the know for sure. Thanks for the help.
