https://www.partzilla.com/search?q=84706-415-000&ui=typeaheadWhere the shoulder of the bolt comes into play is it fits 'inside' the hole of the fender to keep it from moving around and cracking.
A small sleeve of the right size would do the same thing or else a stack of washers of the right size.
Definitely loc11, 90106-MT3-000, SCREW,PAN 6X46I’m not sure they are a specialty fastener for sure. And they are exposed. As long as it works I really don’t care the fender stays in place without them I’m just not crazy about them being gone.
Nope, I get it I’ve been doing the same. And can’t believe I lost them. Anyway, a 6 x 55 button head screw is commonly available and I think a suitable sized bushing could be found or made to slide up to the top of the head. Hell it could be a pen body. When I got divorced one if my prize possessions I had the sell was a 1939 Southbend lathe I restored it was 6 x 36” perfect little machine for making a bushing like I’ll need. It is not structural though it’s just a fender bolt I ran it all last season without them and it was fine.Yes, losing those shoulder bolts for any parts of the fairing are probably one of my top worries, practically unobtanium. Only way I can think of to recreate them is to get a standard button head bolt. Then wrap some stainless wire around it underneath the head to make a new shoulder. Then use baking soda and super glue to fuse it together and with the bolt. Sand/file it to match the original
Or find/make a metal sleeve bushing to slip over the bolt to mimic the shoulder. Dunno...brainstorming.
How thing does it need to be? Something could be 3d printed fairly easily.Yup way I’m leaning too. It’s gotta be better than nothing! And absolutely why I miss my little Sourhbend lathe! I’m sure I can fine some thin wall small tubing and cut it down to make a bush, again maybe a Bic pen body? I can find something that will work. Thanks for your thoughts though!
Does it just need the thin shoulder up by the bolt head or the narrower shoulder down to the threads as well?54mm the shoulder is like 5/8” at a guess?
I caught it in post #25 and saved it.One more time, then I give up.... use this collar as the bushed area on top of your 6 x 55mm bolt...
