bplandis
Not sure I have anything new to add. Took me a little over an hour. Only issue is rubber boots for headlights. One of mine split trying to pull it over fixture. Any suggestions for sliding them over the headlight housing? Cut the center out is only way I can see. I tried a bit of soap to try and help. Pulled hard enough to split one. I took another look at Ibikes post #37 and the housing of the lights I purchased are different which seems to explain why I could not get the boot to slide up far enough to allow the house to still be mounted into the plastic mounting piece.
Both lights from Amazon I listed a few pages back installed without issue. Will report back after a few weeks after I ride it a bit and see if any issues develop. Have yet to ride it at night.
I pulled the cluster loose as the right side (rear brake side) is a little more work to get to. I did not want to damage anything. If I did it again, knowing how it comes apart, I would not pull anything loose. I had the best luck one hand from up top and the other from the bottom. The squeeze of both sides of the headlight plug can take a minute to figure out.
Few pics of both sets of lights I installed. As well as the difference with the left side installed.
