Headlight modulation for LED headlights?
How did you cut the 2 tabs at the bottom? did you use a grinder or dremmel?
Just bend them back and forth a couple of times and they will break off.
I pinch them off with a set of side-cutters.
@st11ray and @beemerphile do you do that with the relatively thick base plates of LED lights? Those are made of much heavier stuff than the base plates of a halogen bulb. I would not think that either method would work well on the LED mounting plate, but if you've actually done it then that shows what I know.
@ST-Traveler since that plate is aluminum (I think), do NOT use a grinder on it. Aluminum tends to plug up a grinding wheel and can either ruin it and can even cause it to explode. After you've removed the tabs, smooth the areas where they were with a hand file.
Yes here as well. I cut off both Evitek F2's and the Sealight S3's with side cutters. The F2 gave up with little drama and the S3 was some kind of molded material and it gave up even easier. I put the tab deep into the crotch of the cutter.@st11ray and @beemerphile do you do that with the relatively thick base plates of LED lights? Those are made of much heavier stuff than the base plates of a halogen bulb. I would not think that either method would work well on the LED mounting plate, but if you've actually done it then that shows what I know.
I still would like a pic of the front of the headlight housing
Thanks,When the plastic is off, you also have free access to the up/down adjustment screw so it is easy to make changes there as needed.
Waiting for darkness
I used a disc sander I use for wood working and it did great, I took my time and didn't overheat it.I used the side cutter to make a groove. Then used the pliers to snap it off on the scored line.
Will do - I am so use to my halogens and all the morning commuting I do, this will hopefully be a big improvement,do give us a critical review on what you think.
If you look at post 37, last pic of it standing vertical... just envision that rotated 90 degrees right. When installed, the braided wire coating has to be at the bottom, and then the cup-shaped shields will also be on the bottom and reflecting up, the spine (heat sink) of the LED's will also be vertical. Basically, you can't very well mess that up if you have the wire at the bottom.There are here.
I still would like a pic of the front of the headlight housing if anyone could snap a quick pic and post it I would appreciate it.
I want to know the orientation of the bulb as seen from the front.
Anyone,Anyone????
My brand new ones said 30,000 hours on the box. They are impressive upgrade for not that much money.While I read the claims of superlong life with LED's, I don't know if they will go 50,000 hours....
I did this last night. it was all the way up and the low beam was still below where I would like it.if you look on your ST1300 the left side of the dash there is a headlight adjustment knob. Try adjusting this first. you have to have the key on.
Do these have built in fans? I did not see any in the pics. I want to order these.This is the marker that I am using. Anything bigger will not fit.....
