'04 ST1300 and GIPro-X
stebel horn, front fork brace, gear shift indicator--hmmm which one first?
Yep, GPX-H01 harness and the display is working like a charm other than not going into Learn mode. I have the harness connect correct as the display is getting power (6...1 countdown etc.) and the speedo is registering wheel speed when in gear...
I love diagnosing electrical problems, they teach one the true meaning of humility.
The display counts down and does the slow L flash... it does not do the faster L flash unless I unplug the instrument panel connector, then it does the faster L flash. However with the instrument panel connector disconnected, no tach, no speedo, and darkness reigns on the instrument panel.
Thanks for your assistance so far.
You have a point there. This gizmo hooks into a lead from the ECU to read the gear position. The question is: if this information is already known to the ECU why the heck didn't Uncle Soichiro just spring for another display and show it to the rider? It can't be a cost consideration with the ST's price.
Pete
I ordered mine yesterday and will get it sometime next week. I will get some picks on several locations where it could be mounted. I am not sure where it will ultimately wind up at this point.
Here's mine. Not a very good picture, but it's a small crop from a larger image. I can try to get a better one later.
If you're going to dissamble the instrument pod to mount it there, there's one mistake in the shop manual. The manual shows, IIRC, 9 screws that hold the 2 halves together. In addition, there are two small screws on the back, behind the headlight adjuster, that need to come out, too.
