Why, what happened?DO NOT DUMP HALF A BOTTLE OF SEAFOAM IN YOUR GAS TANK
Half a bottle is 8 oz. At the recommended 1 oz. per gallon, half a bottle is the recommended quantity for a full tank of gas.
Even at 3/4 tank, a half bottle of seafoam shouldn't hurt anythingAndrew,
Yes that is what is recommended but my tank was not full at the time, maybe 3/4. Still trying to determine what the actual issue is.
My intake valves were filthy and I think I may have broken loose way too much carbon and now I have an FI light. Knock sensor code 25 but not the usual rpm/speed drop and no drivability issues so not jumping to the computer .
Start your own, and stop trying to steal mine or I’ll block your speed dial to the white courtesy phoneI wish my customers would leave reviews too….![]()
UNSOLICITED, of course!I wish my customers would leave reviews too….![]()
I suspect a tub of it will last you a lifetime. Unless you offer to mount tires for friends.Larry recommended Hunter tire paste so I’ll have that for my next tire change.
With Ride On I used the middle suggested quantity front and rear, no issue when riding or changing the tyre.
Upt'North.
Yes but over there you ride on the opposite side of the road, thus your tires spin in reverse of ours.
I believe that their toilets also flush in the other direction too.Yes but over there you ride on the opposite side of the road, thus your tires spin in reverse of ours.
I believe that their toilets also flush in the other direction too.![]()
in a severe case, yes. If the bead does not seat properly, it might still seal the air in the tire. As you inflate the tire, the bead forced by the air pressure, slides over the little 'retaining' bump in the rim and comes to rest against the outside flange. If you missed a spot on the tire when slathering on the Hunter Tire Paste (or dish soap, or whatever you use (nose oil, anyone?Can you visually inspect the tire to see if the tire is not properly seated? Can it be seen once the tire is on the wheel and the tire is filled with air? I just installed tires on my bike and had balance issues. Seems ok, sometimes theres an odd bounce to the front end. It comes and goes so it's hard to tell if it's the surface of the roadway or a balance issue.
Pet peeve of mine. Use proper tire mounting lube, there is a reason that it exists.or dish soap,
