Their 5/21W (as tail/brake-light) so the different brightness is given...I'll have to check the incandescents they replaced, to see what the difference is with them, but I doubt it's 4x.
Jim
Can't we put a video on this site ?
Ad
Throw it on YouTube and link it into here...Can't we put a video on this site ?
Yep, Type 2 is the way to go, still I'd like the white a bit dimmer though...Like this should not be a problem in any country.
I have used these bulbs on other bikes and recommend them. The white is very bright like a spot, very good for added visibility. The yellow flash is very noticeable. I needed to replace the flasher with an LED flasher on other bikes to prevent hyper flash. I haven't installed them on my ST yet. I'll post pics when done.I'd opt for some type 2 Dual Colour Switchback LEDs, but they don't come in "dual power", meaning the white side is a bit too bright (not like the 5W side of a standard 1157 incandescent bulb...)
Anyone having more luck in this?
Nosegear, that's what I did. I did not care to wire in a resistor and find a place for it to draw more power. I simply replaced the flasher relay unit with a plug n play LED compatible flasher relay.Load resistors are only required when using LED light bulbs, and are meant to make the blinker relay detect sufficient load to blink normally. Without the resistor the relay would blink at a much higher frequency - as if a normal blinker bulb has burned out. There's a resistor mounted in parallel with each LED bulb to increase the total power consumption, and as they are extra do-dads. Fairly small, though, and easily fitted inside the mirror cover. Personally I hated the idea of having to add resistors to 'burn off extra power' and replaced the blinker relay with a version suited for LED lights. I don't need those resistors anymore.
However, combined with the proper switchback LEDs you can have your turn indicators shine bright white while not blinking, and shine yellow/orange while indicating. When you stop indicating, the white light comes on again after half a second or so with most LEDs. This type of lighting will make you more visible indeed! That looks like this (it's an ST1300, but the idea is the same): https://www.youtube.com/watch?t=9&v=GcDtTmCkPag
The original unit can be warmed e.g. in hot water, after which some slow & steady pulling will enable you to pull the original lens off. The clear lens is then indeed glued in place.
