Hi Ad,clear lenses for our ST1100
thank you for this nice looking clear lenses! My bike looks like new now) After having delivered led bulbs, i decided to mount clear lenses, it took about 15 min to replace them, using hairdryer and glow stick glue gun. Very easy)
Two color led bulbs I ordered with from aliexpress. Looks ok, much brighter that stock incandescent bulbs, and they have feature which shuts off white leds when orange leds are on. no need to install relay or tweak somehow wiring. Now need to figure out how to replace rear bulbs )
Then i decided to do something with relay. First, I bought automotive relay for experiments and googled how to tweak flashing frequency - found out that best way to do it is to replace shunt resistor with higher impedance. I soldered piece of thin (0.5mm in diameter) copper wire instead of resistor and started to add length to it. At about 50 cm length of wire relay starts to click properly with two led bulbs. If disconnect one - relay begins to click with double frequency as it was designed - so burnt bulb detection feature was saved).
then I cut open my ST1100 turn relay and did the same to it. Relay is glued with epoxy resin so need to use dremel thing to remove it. PCB is glued to case too, so I decided to cut shunt resistor without getting it out from the case and soldered my wire to it. To make it easier to hide this wire in the relay case I winded this piece of wire on the screwdriver and had nice looking spiral. Need not mention that wire must have insulation - I used wire with enamel insulation. Put this spiral inside relay case and glued it back - now I'm having two relays adjusted to work with leds)
