That’s my boyI COME AS A SPEAKER OF AUTHORITY: The L01 is the only ECU that will work on the 03/04. Only on the <2005 can you interchange the L01 or 38770-mcs-a31. The R21 is COMPLETELY DIFFERENT starting in 2008 [I have pics]/
Thanks for the info.That’s my boy
Thanks for the link. It disappeared into the archive of history!!Good to know. I wasn't convinced back in 2021 but kept my mouth shut because I had never tried swapping them.
Greater numbers of people will be looking for fewer numbers of remaining ECM's. You might consider going back to that post and correcting it for the benefit of others who might find it while searching for interchangeability information.
Hello Aniwack. It appears I have a bad L01 on a 2005. Pardon my asking, It looks like your sentence is saying greater than 2005 can use A31, though your showing a less than sign. Do you mean 2005 through 2007 can use the A31? If so, can you give me some insight how you came to know this? It's a good bit of cash to layout... Thanks for the help!I COME AS A SPEAKER OF AUTHORITY: The L01 is the only ECU that will work on the 03/04. Only on the <2005 can you interchange the L01 or 38770-mcs-a31. The R21 is COMPLETELY DIFFERENT starting in 2008 [I have pics]/
The story has a happy ending. Trusting in Aniwak's authority, the A31 ECU is working perfectly replacing a L01 based on my 240 mile test ride. I worked with my independent mechanic (Deftone Cycles, Chagrin Falls OH) to complete the diagnostics. After swapping positions of the knock sensors with no change in error code, replacing a sensor wiring harness that crumbled on removal, and testing and inspection of the wiring harness, I purchased and installed the A31. The bike is an 05, no ABS. Thank you ST-Owners.Hello Aniwack. It appears I have a bad L01 on a 2005. Pardon my asking, It looks like your sentence is saying greater than 2005 can use A31, though your showing a less than sign. Do you mean 2005 through 2007 can use the A31? If so, can you give me some insight how you came to know this? It's a good bit of cash to layout... Thanks for the help!
Very good question. The mechanic had me come to the shop after the sensors were swapped and the sub-harness replaced to see check if the codes changed. The same code occurred. When the ECU arrived I returned to the shop and confirmed the code was still occurring, then swapped the ECUs. Bike started on first try and the code no longer indicated even after running over 5000 rpm for over 30 seconds. Then a few days later took it out for the 240 mile run and pushed pretty hard.Glad to hear your bike is repaired.
I have one question, when you said you replaced your sub wire harness because it crumbled when you removed it, did you happen to test ride the bike with your old ECU before you installed the new one?
I ask because I have found several bikes that have been repaired by replacing this harness instead of the ECU, and was just curious of which of these two things solved your problem.
OK, question for the Experts!
Since an '05 - '07 ECU will not work on a '04 (according from the info in this thread and I didn't miss understand) Would you be able to swap out the entire '04 harness with an '05 harness and the ECU, to have the '05 ECU work on your '04?
Just incase my '04 ECU goes belly up. Since I have a '05 ECU/Harness/parts bike.
Aniwak stated that the L01 ECU is the only one to work on the 03-04, and the L01 and A31 both worked on the 05. Therefore the connectors (plugs) for all L01 bikes and A31 bikes should be the same and that includes 03-05. I only have personal experience with the 05.Trying to catch up on this thread.
Still not clear to me at this point: Does the 05 ECU fit the 04 harness or do they have different plug configurations?
.......the connectors (plugs) for all L01 bikes and A31 bikes should be the same .....
Would you be able to swap out the entire '04 harness with an '05 harness .......
If the part numbers are identical, yes. It is the exact same part. If not - I doubt it and I would not be the first to try it. Search the forums to see if anyone has gone there.So 03 to 07 should have the same ECU plugs.
Plugs being the same, what are the differences between an 04 and an 05 harness?
For the sake of discussion, supposing this interchangeability works, is there a source of working ECUs?
I do not know. @Igofar stated specifically in this thread (see above) that the A31 will not work on the 03/04. only on the 05. My testimony is that it did work on my 05. I have no knowledge of the 03/04.Yes. Would be good to know where @ST_Pap_Pap found his A31...and why it wouldn't work on 03/04!
Okay, I have an '07. Where would I get a spare A31?I do not know. @Igofar stated specifically in this thread (see above) that the A31 will not work on the 03/04. only on the 05. My testimony is that it did work on my 05. I have no knowledge of the 03/04.
