- Joined
- Mar 18, 2006
- Messages
- 2,998
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
That may help explain why at times, when getting close to needing a bleed, a pedal that feels somewhat spongy at rest still turns out to be a bit firmer while in motion?
It is certainly a possibility, but not a 100% diagnosis. For example, a distorted (oval) SMC bore may produce the same result.
But think of this little scenario. You have an air bubble in the brake line. Imagine that it is located between the SMC and the rear caliper. That line goes up from the SMC to the proportional control valve, past the bleed valve behind the mid fairing near your right knee (near the ignition coil) and then down to the rear caliper outer pistons.
When you are stationary, the SMC is not activated and pressing the rear brake pedal causes fluid to pass the SMC and through that brake line - applying the two outer pistons of the rear caliper. (This is why you get fluid out of the rear outer bleed valve when bleeding and you press the brake pedal).
With me so far ? Ok - well there is an air bubble in that line, so when you press the brake pedal, the pedal feels soft as it squeezes the air bubble. Pressing it a few times puts more fluid into the line and it gets a bit firmer. Wait a while and the fluid returns via the compensation port and it is as soft as it was before.
When you are moving and apply the brakes, the SMC is activated and that applies pressure to the same line - squeezing the air bubble and applying pressure to the rear pads. Not as much as it should because of the air bubble - but you cannot feel this sponginess.
With the SMC applied, the pressure from pressing the rear brake pedal cannot push any more fluid past the SMC - the SMC has already done that - so the brake pedal now feels firm.
This to me, is a good indication of where the air bubble is in a spongey rear brake. And it is difficult to get rid of, because there is an 'n' shaped bend in the brake line behind the headlights - and a couple of unions around the Proportional Control Valve. Tapping, flexing and a vacuum really help to shift this and bleed it out at the valve near your right knee.
You can verify this with help from a friend. Get them to squeeze the caliper toward the fork, to apply the SMC. Press the brake pedal. Does it feel firm ?
Keep your foot on the brake pedal, and release the SMC. The brake pedal may dip as the SMC releases its pressure on the bubble and the brake pedal takes up the slack.
This is just me hypothesising - but its based on my own experience, and I have convinced myself from observations. Just waiting for someone else to disprove it !!
