We agree. I said it ended with the paralever which first came to the R100GS in 1988 and later to the K bikes, the R100R, and finally the oilheads. Monolevers jacked just like the twin-shockers all the way to the end of the series in 1995. You learn fast not to chop the throttle in a turn. On the other hand, if you brake early and power through the turn, you can use the shaft-jacking effect to increase the ground clearance.Oh come on Lee. The shaft jacking on /5, 6, 7s was extreme and carried on through the monoshock 80s boxers. If ever anyone doubted the adage "never, ever, ever, ever, ever chop the throttle in a turn" found out the hard way when their BMW sank two inches mid-corner and ground a hole in the right hand valve cover before levering the wheels off the pavement or dug the left-side centerstand pedal into the pavement where it broke off being so cheesy. At least after it broke off there was more ground clearance on the left side. Next up on that side was the tang for the side stand, properly ground off from factory length.
