- Joined
- Dec 1, 2004
- Messages
- 13,217
- Age
- 61
- Bike
- '21 RT / '24 GSA
There is a location on the ST1300 that is great for a switched
power tap in case you just have a couple things to power or
you need a switched tap for your fuse box.
Below are the steps to get to the power location:
- Press the side clip..
- and it slides out
- It appears this thin fuse holder is on ABS Only bikes, for non-ABS bikes you'll tap into a different wire.
- Tap into the RED wire w/GREEN stripe..
- For Non-ABS bikes, you'll still tap into the red wire w/green strip that is assigned to your 15 A ACC circuit.
This power tap will only be hot when the ignition key is in the ON or ACC positions. I used a posi-tap connector.
