I've just added a footnote to post#1 of that linked article - regarding the way I wired in the hitachi connectors. I wish now that I had done it differently
I was very impressed with your article, John, and your usual attention to detail. Don't believe I read how long the whole project took you - hours, days, weeks?
For the benefit of others I would mention the topic of margins when selecting wires/cables.
We cannot just rely on the current draw from a particular accessory, but also need to allow for voltage drop, whether encased in conduit and the environment where the cable is situated e.g. in engine bay.
Voltage drop VD - suppose the power used was 50W, then current draw would be 50W/12V= 4.2A. So one might be fooled into thinking a 0.5 sq mm cable (11 A) might be sufficient. Wire length can have significant effect on VD. If a voltage drop of < 2% is required, this cable is not sufficient as VD = 4.2 x Length x Resistance per metre. If length from positive terminal and back to negative terminal is 5m,
VD = 4.2 x 5 x 0.037 = 0.77V or 6.4% of 12V, taking the Resistance/m as 0.037 ohms/m.
So cable would be OK for current draw but not for the length of the cable as >2%.
Temperature Environment - although cable length should definitely be allowed for, also be aware of where the cable is to be situated. Also, in the UK, the cables tend to be categorised according to cross-sectional area, the specification will stipulate the temperature environment for its suitability - usually 20 degrees C. So if the temperature environment is 95C, that is significantly different.
Hope that's useful
Paul
