Picked up a Facet pump (model 60304) a while ago to carry as a backup when riding in case my '98 ST1100 fuel pump quits on me. I am going to fit it as described in this AOW article:
After fitting and testing it out, my original plan was to remove it and carry it in a saddlebag. If the fuel pump quits while riding, I would fit the facet, hook up the wiring and (hopefully) continue on.
But I am thinking now to just install it permanently and have a selector switch that would allow me to run either pump. The description for the Facet pump at Pegasus Auto Racing says that you can pull fuel through the pump when it is turned off. Anyone see a problem with this?
www.pegasusautoracing.com
Facet Posi-Flo 12v Fuel Pump Kit, 1/8 NPT, 1.0-2.0 psi | Pegasus Auto Racing Supplies
This Facet Posi-Flow, Low Pressure Fuel Pump Kit is for low fuel requirements of carbureted engines up to about 100 horsepower. Kit contains pump, mounting hardware, filter and adapter to accept 5/16" fuel hose.
