FYI, I had to "reconfigure" the bails on my ST1300.The bail/clip issue may just be for the ST1100s.
I keep trying to come up with a better solution to replace those bails which most folks find to be a pain.
The bending applies to the bails hitting the Evitek G4 bulb's fan and preventing it from seating properly. A standard bulb doesn't/shouldn't require bending the bail.
Seeing the stock bulb/bail/headlight assembly makes it easy to see how the bail has to be manipulated to be released and reinstalled.
Push-slide-release-remove. Reverse procedure to secure the bulb. This was the same for installing my 55/60W bulbs in the ST as was any H4 swap I've ever done for my other Hondas. The difference was being able to remove those headlight assemblies in a minute.
The ease/difficulty of actual manipulation of the ST's bail is a result of varying factors among individual owners. There's also one mention from another member that using the shims (for the 1100) added to the difficulty of closing the bail (due to their added thickness). Others haven't remark on that being a problem.
I was able (barely) to swap my 45/45W bulbs for 55/60W without removing any plastic. I will probably use Bob's method to install the Eviteks when they get here. (Unless there's an easier method...)
The bending applies to the bails hitting the Evitek G4 bulb's fan and preventing it from seating properly...
As for the headlights, I never noticed any issues with the wire holds hitting the fans. I'll have to take a second look at those.
Am I missing something in this conversation?
I thought Unc had a problem with his 1100's bails hitting the fan.
And remember, once the bails have been "reconfigured" for clearance, you should never have to mess with them again. I carry a spare LED bulb, but don't need to move the bail. Can squat in front of the bike and reach up behind the headlight assembly to remove/replace the bulb.
I do not know if they're a standard base or not, and I doubt there is an industry standard ... yet. My spare is a second set of EVITEK G6 bulbs. OTOH, the base-plate's fitment to your headlight assembly is a standard.I assume that the 'socket' for the LEDs is standard ...
Correct. Bails hit the fan on a ST1100 and need to be bent to provide proper seating of the assembly. ST1300 I don't know.
Okay, thanks for clearing that up. So this is only a problem if you're dealing with the interface between new and old technology.![]()
Uncle Phil said:I assume that the 'socket' for the LEDs is standard
hoowasat said:I carry a spare LED bulb, but don't need to move the bail.
This begs begs a similar question to Unc's— assuming the G6 socket fits an H4 bulb if a G6 blew could you run an incandescent H4 off that ballast module? Even if the socket and bulb match were talking a big difference in current demanded.
You have to bend them or the LED bulb sits wrong.You should not have to bend them, like Bob said, just learn how they work.
