Article [13] ST1300 - Switched Power Tap
Re: ST1300-Switched Power Tap
Mellow, Do you think this red/green wire to the acc turn would be ok to wire a Corbin heated seat hot wire to???
That's a pretty low-amp wire so I'm not sure that would be a good idea.. how many amps does the seat pull?
i was just looking at it and there is a red and white main wire running into that fuse block. do you think I could just tap into that one? The hot wire from the seat has a 10 amp fuse in it.
Corbin web site says 5 amps is what the seat pulls
l would use the one in the article then. Should work fine.
My reason for finding this was as a trigger to a relay on a fuse block. That fuse block would then power other items.
I think if it's just the seat you are concerned with, you should be fine.
I appreciate the help. Pretty handy with this stuff usually, just kinda leary on a $10,000 bike you know. Don't want to screw something up.:confused:
A couple of years back when I bought a used Corbin for my '05, Corbin provided a power tap that you inserted into the ACC fuse, and basically put two fuses into it. One protects the original circuit, and the other your new circuit. It also came with a nylon rain cover because you have to leave the little cover on the fuse panel open. Of course, you should not put heavy loads on the original circuit that would exceed the wire capacity (install a fuse block or relayed circuit instead).
You can find these at automotive supply stores.....
http://www.cooperbussmann.com/images/49377357-4055-4945-a6a2-1e7bb04a08b9.JPG
Re: Switched Power Tap
This looks easy enough to do, but I have a dumb question - is the point where the RED wire w/GREEN stripe is tapped into on the upstream or downstream side of the fuse? Which fuse does it come from (or go to)? It would be easy enough to find out after tapping into the wire, but I'd rather know (or be able to find out) before tapping into it. :confused:
I don't honestly know. Any thing I have tapped into that will have it's own fuse but I understand what you're saying, you want to know which fuse could be the problem if there was an issue.
When I get some time after work today, I'll pull that fuse and see if my tap is still good.
I never thought about it LOL. Just tapped it and fused a line to the relay coil. You could just pull the fuse and probe it. btw these multimeter probe tip adapters come in handy for that kind of thing.
On a Non-ABS bike it comes from fuse "E" which is a 15 amp fuse.
On an ABS bike it comes from fuse "F" which is also a 15 amp fuse.
On both bikes the red wire w/green stripe is downstream of the fuse. On both bikes they are fed from the 65 amp main fuse. They provide power for the ACC at the ignition switch. Hope this helps.
Mark
Mark
Thank you sir!
Interesting thread. My 2007 St1300A does not have this circuit. Will find the red/green wire and test it with ACC on and ACC off.
Aha! I found it - it has moved to the side and the text small and vertically aligned.
Off to get a decent posi-tap .....:CanFlag1:
Can't begin to tell you how much time this saved me hooking up my Autocom tonight. It's threads like this that make this site invaluable. And friends like you all that make it fun.
I'm happy to take all the credit for all the contributions I didn't make - but DITTO here ...
:slv11: :nuts1:
Hi Mellow,
Although I've managed to hook up my GPS on switched power quite easily on my St1100, I still consider myself as a big zero when it comes to electrical, which is why I find this thread quite useful. As far as my 1300 goes, I ran the wire (which I hooked up to a fuse) from the handlebars to the OEM fusebox and tapped it to the red/green wire. Quick and painless, thanks to your pics. Now here's my stupid question: where do I hook up the ground? I've read in the pas that green is always ground on Honda's, so do I hook up to anything that's green?
Hi Mellow,
I typically go to the battery - connection for a ground when I can.
Hi Mellow,
Green is ground, but always bring it back to the battery if you can, That said, I have tapped some stuff into the Green Ground
I'll chime in that on something with a minimal draw like a GPS I'd be comfortable just taking a ground right to the frame rather than all the way back to the battery, but that's just me.
