Okay,
I had some dragging and Igofar talked me through some inspection and tuning advice. I found a pinched boot on the SMC side and a missing tiny o-ring on the rear. Rear pads were nearly new, so just cleaned everything and inspected the rear wheel bearings while I was in the vicinity. The front pads were maybe 50% worn, but the SMC side had a slight angle; so I put new Honda pads (06455-MCS-G02) on both sides.
Cleaned all the pistons, springs, used Q-tips to clean the slides. Reassembled everything carefully, checking that all the calipers freely floated on the pins (and no pinched boots this time!). I opened the front MC to check level. Visually checked rear MC and it was at upper line.
As far as I can tell everything went back together okay, no hiccups noted. Unfortunately the front wheel seems to be dragging and the rear wheel spins freely (a reversal of the original issue). I cracked a few bleeder screws and no residual pressure was observed. Yet the front wheel has a fair amount of resistance. I took it for a short ride, just in case bedding the pads would make a difference. Drove about 1/2 mile and coasted to a stop - all three discs were cool. I drove around slowly increasing speeds and doing firm stops with front or rear brakes. Then went for about ten mile loop on highway. I averaged about 45mpg if you believe the meter at speeds of around 65 mph. When I got home, none of the discs were excessively hot to the touch - but front wheel still barely turns.
I'm sure I checked a few other things, but probably forgot something important. What else can I check or adjust.
PS: The SMC has about 750 miles on it. I bled the system about five times before I got everything firmed up. After the new SMC, before I took everything apart, both the front and rear brakes felt nice and firm. After replacing the pads things were a bit spongy till about halfway through the test ride. I'm guessing maybe it took a while to fully push out all the pistons, but it could be something else.
