- Joined
- Mar 18, 2006
- Messages
- 2,869
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
My brakes often groan when I back it out of the garage. I don't ride it as frequently as I used to. But they never do this when I put it away after even a short ride.
Yes, my brakes always sssshhhhhh when new pads are fitted until everything settles down.
I haven't seen mention of your pad springs - it is possible to put them in the wrong way round. Also whether your slider pins are properly fitted into their mating hole or rubber bush. It is very difficult to separate the two halves of the left caliper, because of the SMC brake hoses, but the right hand side separates easily, so that is a possibility.
Have you checked the clearance as the disc rotates through the caliper bracket ? You'd hear it if it was catching, but if one of the clearances is tight, it might point to the real problem. Check it on both sides of the disc. You are checking the point where the disc rotor passes through the bracket where the chrome retainer clip is fitted. Clean the feeler gauge, hold it against the top of the disc rotor and rotate the wheel backwards . both sides of the rotor, both discs.
