I can't get Apple maps running windows to add a destination/stop/via point. What am I doing wrong?
Did you take advantage on it, might as well? lolOn a route I know well Google Maps offered me an alternative route home which I was stupid enough to take. I ended up in a city, at a junction with hookers and drugs dealers, with all of them trying to sell me their services
But this is not a nav if I understand it right. It just reflects your phone's map app like google map and navigates A to B (or up to 10 map points). For the custom routes you still need an app (like OsmAnd or alike) to navigate a custom route.Apple CarPlay/Android Auto display
Yeah... but such a "salesman address finder" is so convenient...But this is not a nav if I understand it right.
You are right I installed the SCENIC app to allow the creation of routes and importation of GPX files. I have yet to see how it will work in the real world but my hopes are high.But this is not a nav if I understand it right. It just reflects your phone's map app like google map and navigates A to B (or up to 10 map points). For the custom routes you still need an app (like OsmAnd or alike) to navigate a custom route.
This is a feature of most navigation apps including Google maps. Things like real time traffic and weather do require an active data source though.One major, major advantage is that on a state-by-state basis it's entirely offline. No connection needed once the map is downloaded.
I like the green tape! Where are people grabbing Keyed power near the handle bars and at the saddle bags? I have a 93 1100. Is there a good thread on this?This is what I do occasionally as well. I carry an atlas in the bags that I review at night. If the way is unfamiliar or has numerous turns, I write notes similar with a felt tip marker...waypoints, destination names, miles between. It goes into a clear plastic sleeve and gets taped to the tank. Just a quick glance is all it takes.
A lot of folks install an auxiliary fuse block (often in the tailpiece for easy access) and run stuff from there.I like the green tape! Where are people grabbing Keyed power near the handle bars and at the saddle bags? I have a 93 1100. Is there a good thread on this?
In addition to the single Honda supplied switched hot wire, there are 4 slots on the back of the fuse block that provide "switched" non-fused power. Crimp a male spade lug on a wire and plug the spade lug into the back side of the fuse block.A lot of folks install an auxiliary fuse block (often in the tailpiece for easy access) and run stuff from there.
The simple way is to get a relay that can carry the power and run a switched hot to the trigger the auxiliary fuse block from the original fuse block.
I know ABSII (96 and later) have a switched hot wire for use behind the original fuse block.
I do not know if that is available on a 93.
