It is possible that these numbers are correct - as previously asked does it look like the the rocker covers and tupperware have been removed?
Paula
Paula
Paula
A couple of thoughts. I've done several valve clearance inspections and shim changes on the ST1300. The valve clearance measurement task may or may not have been performed.
If I recall correctly, you had to go back after the 16K service was performed to ask for the measures. It is possible that the valve clearance task was performed, all valves were in spec, no measurements were taken, and the Service Manager made up the measurements and gave them to you to make the problem go away. It would be difficult to tell if the valve covers were pulled.
So, you could either trust that the work was done or go back in to the dealership and find out what happened. That may require that you speak with the mechanic.
..I would do it yourself, write down THOSE numbers and take them to the dealership for a refund as well contact Honda to let them know about this dealerships service department.
Paula
The brake and clutch fluid was intentionally skipped at 12 because, per the tech, the fluid "looked good" and thought it could go until the 16K inertval.
Migrate away from this dealer as soon as reasonably possible. Brake and clutch fluid absorb air over time from very small air holes in the cabling/connections. That is why there is a mileage and time limit on the recommended change - 12,000 miles or 2 years, whichever comes first. If the "mechanic" said it looks good that is the wrong answer.
This is information I wish I'd had...certainly no reason to have skipped this other than what the tech told me. Does this air absorption negatively affect the bike's performance or does it cause some damage to the workings of the bike?
Bob - Good luck with your redo. To answer your question there is a spreadsheet on the tolerances and also a graphic for recording measurements in the article section at the top of the main page. I use the "ST1100 Valve Clearance Worksheet" to record the measurements and put in my maintenance file.
The reason motorcycles have such frequent change intervals for brake/clutch fluids is because they tend to sit for long periods (on average), such as when stored during the winter in most states. That's why cars can go much longer between changes- almost daily use, year round. When parked is when a vehicle tends to absorb most of the moisture. Its not air that you are immediately worried about- brake fluid acts like a sponge for moisture. If you open a bottle of brake fluid and leave the cap off, come back a week later and the fluid level will be HIGHER, because it absorbed moisture. That is why once you open a bottle of brake fluid, it has a short shelf life. If you only use a partial bottle, don't put it on the shelf and think you will use the rest next year. The brake fluid will absorb the moisture in the air that is in the upper half of the bottle. Each time you open it, it gets a fresh batch of air/moisture.
The moisture will cause several things to happen. First, it does cause rust on brake components. Next, it compresses easier than brake fluid, which means spongy brakes. And when that fluid gets in the calipers, which see lots of heat, that moisture has a much lower boiling point than brake fluid, which will cause performance problems and possible damage to brake components. It also separates the moisture from the brake fluid, and the heat separates air out of the moisture. Now you have water concentrated in the system, and you have air pockets. All of this negatively affects performance, and the life of the brake parts.
So if you are doing like me, and riding the bike every day, you could actually extend the change interval. But if you are the average rider, you do want to make sure its done at the rated interval. After my bike does get parked for the winter, I'll be changing mine first thing in the spring- after it has absorbed a winter's worth of moisture.
Jim
