After my first ride the the north of my state, 195 miles and half of it in the dark, I'm very pleased with the car tire.
Thank you, @970mike !!
If you wouldn't mind, could you go for a longer ride and tell us how much tread is left at 30,000?
Why certainly, I will.If you wouldn't mind, could you go for a longer ride and tell us how much tread is left at 30,000?
I would think that most car tires vastly outperform motorcycle tires insofar as water evacuation goes. That would not be be a big concern for me if I was considering going dark.I live in the Great North Wet, I want to know how it handles rain. For all the talk about tires, some of us tend to forget that one of the main functions is to pump water off the pavement, away from itself...
Unless you have a couple hundred pounds in that trailer it isn't going to matter.Remember, too, that many or most of the miles will be pulling a Bushtec Roadstar, so most riders, including @970mike here, will get more miles from the same tire, than I will.
I initially thought that way, too... the first indicator of the difference a trailer makes, was the marked decrease in gas mileage.Unless you have a couple hundred pounds in that trailer it isn't going to matter.
I don't know what a trailer does to MPG, but in terms of overall lifespan the trailer isn't going to shorten the length of the car tire nearly as much as the bike tire. I've never had any car tire get less than 30K miles. The Bridgestone DriveGuard RF tire got 36k+. And I changed them before they were completely done.I initially thought that way, too... the first indicator of the difference a trailer makes, was the marked decrease in gas mileage.
From pre-trailer 42mpg, to a current average of 32 to 34mpg.
The trailer is not heavy, and my pup only weighs 90lbs.
And the last few hundred miles on my last rear tire seemed to evaporate almost overnight.
But we shall see in 20- to 30k more miles, won't we?
AA wet traction rating, highest available.I live in the Great North Wet, I want to know how it handles rain. For all the talk about tires, some of us tend to forget that one of the main functions is to pump water off the pavement, away from itself...
From the pictures @970mike posted, the tread looks like a 70/30 adventure tire. You might consider it, unless you need a very aggressive knobby.I won't be going Dark on my GSA, though. Not that I can foresee at this point.
I've used the No Mar many times, although I've never owned one.
Even with my friend - who has changed many more tires than i - doing most of the work, both of us struggled for nearly an hour trying to get the second bead on my ST1300 rim, and ended up taking it to a car tire shop who put it on for ten bucks.
Hope you have better luck, or better outcome.
