Old thread, I know, but it's the only
one I found answering the question of "which incandescent lightbulbs are a direct replacement for the standard factory bulbs"
on the ST 1300 (in my case it's a 2007 model).
I'm not trying to do an LED conversion
--at least not yet.
If and when you do you may want a new turn signal flasher/relay designed to work with LED bulbs. With the stock flasher/relay LEDs will flash rapidly as they lack the load to trigger the flasher/relay properly. Old school uses resistors to restore the normal flash rate but you need one for each bulb. Just a little info for if-when.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
