Thanks for your help guys. There seems to be a consensus. Safe riding.
I also have been using Rotella T6 5W40 Synthetic, but after reading 540rat blog on oils, I may be changing to a different brand.
http://540ratblog.wordpress.com/
I was convinced to read that a couple of years ago but anyone else can stop after his Reason #1. I'm not running a big bore pushrod rat motor. The ST engines are overbuilt for the use we put them to and do not tax their lubricating oil. There is "good enough" and there is good enough to run to 250,000 miles or more with generous oil change intervals on engines and oils designed and blended over two decades ago.I also have been using Rotella T6 5W40 Synthetic, but after reading 540rat blog on oils, I may be changing to a different brand.
I recommend conventional oil - better for a wet clutch than full synthetic.
Don't know if I would call that statement fake news or not, but if you were to call Blackstone Lab and ask several folks who work there, and who ride motorcycles, I think you'd be surprised to find that none of them would use synthetic oil in their bikes.
Most of the ones I talked to said they saw no need to spend the money on synthetic oil, or even blended synthetic oil (which could simply mean a cap full of synthetic mixed in normal dino oil to call it blended) when after years of testing oils they felt that the quality of the modern dino oils was, like Dave said, Good enough.
.02
THAT is simply not true. Fake news, shall we say?
If your manual says to use synthetic then that's what you do. If it does not stipulate this then it's discretionary and your decision could be based on type of riding you do in terms of duration, mix of city/highway, outside temperature and #of km per annum. 99% of my riding is at least 2 - 3 hours long on highways and back roads at outside temps of 10 to 35C
I've been using Rotella T dino 15w/40 for 15 years, change oil and filter around August 1 and then again mid November as part of storage process for winter season. Air and sub filter checked once per year and changed every two years. My annual mileage is relatively low and change oil timing is length of time driven vs. km. I think if you keep whole system clean with routine maintenance you're going to avoid oil related wear. I suppose a synthetic oil might be marginally better in protecting the engine but given my riding situation the difference is effectively irrelevant IMHO.
OK, Mr. Bush , tell me why you think that ? Isn't synthetic slicker than dino oil ?
Startups literally looked like an insect fogger until the oil burned out of the cylinders. Went back to dino oil and the leakage went away.
