This work was gt to have now I will not have missing when put them back on thanks gt job
This is the wayjust wanted to thank you for doing this!!!! My first time taking these off..
This is great. Does anyone know the PN's for these various bolt/fasteners. A few of mine have disappeared and I'd like to replace them. Thanks.
Great idea! Thank you! /r BradWhat do you do with all the fasteners when you take off your Tupperware?
Well I made these worksheets to keep track of mine.
The idea is as you remove the fasteners, you place them on the correct spot on the worksheet. It helps me keep track of all the parts and it reminds me of all the fasteners that have to be removed first before you try to pull the piece off. Also, each fastener is numbered so you can see the location where it came from - and where to put it back.
Note, I have labeled some of the socket bolts as 5mm or 6mm - this is the thread size. Also there are two different sizes for the trim clips - one has a golf T shaped head and the other is flat.
This is what the sheets look like loaded up:
3rd worksheet added:
Here are the links to the full page pdf files:
Page 1
Page 2
Page 3
1-13-2012 Update
"The Dan" added numbers (in red) for each fastener and wanted to share. Here are links to the files - (Thx Dan)
Page 1 (with numbers)
Page 2 (with numbers)
Page 3 (with numbers)
