Article [13] ST1300 - TupperWare Worksheet
S Cal
What do you do with all the fasteners when you take off your Tupperware?
Well I made these worksheets to keep track of mine.
The idea is as you remove the fasteners, you place them on the correct spot on the worksheet. It helps me keep track of all the parts and it reminds me of all the fasteners that have to be removed first before you try to pull the piece off. Also, each fastener is numbered so you can see the location where it came from - and where to put it back.
Note, I have labeled some of the socket bolts as 5mm or 6mm - this is the thread size. Also there are two different sizes for the trim clips - one has a golf T shaped head and the other is flat.
This is what the sheets look like loaded up:
3rd worksheet added:
Here are the links to the full page pdf files:
Page 1
Page 2
Page 3
1-13-2012 Update
"The Dan" added numbers (in red) for each fastener and wanted to share. Here are links to the files - (Thx Dan)
Page 1 (with numbers)
Page 2 (with numbers)
Page 3 (with numbers)
  • TupperWare Worksheet page 1.pdf
  • TupperWare Worksheet page 2.pdf
  • TupperWare Worksheet page 3.pdf
  • TupperWare Worksheet page 1 with numbers.pdf
  • TupperWare Worksheet page 2 with numbers.pdf
  • TupperWare Worksheet page 3 with numbers.pdf
Re: TupperWare Worksheet
Great idea!
I've always put the rivets and bolts into an egg carton in the order in which I removed them. But I'll definately convert to your method.
Thanks!
Great idea John, and very well done!!! Thanks for sharing!!! :hat1:
DAYUM!!!
With something like this, even I might be able to undress 'er!!!!
THANKS!!!:bow1:
Yes, very nice.... I usu use an egg crate or some double stick tape to hold the buggers.
Very impressive. I've used little snack size baggies that are labeled, but I like this a lot better.
I thought I was organized, but you are GOOD! Thanks.
Jefro.
