Article [13] ST1300 - Saddlebag Power
Re: Saddlebag Power
Just did mine.
I went a slightly different route because I wanted two cigarette light adapters.
I used the PKT-001-48 and PTB-007 other than that install was the same.
Thanks for the write up Joe.
Re: Saddlebag Power
Glad it worked out for you, I with I would have done this a long time ago.
Re: Saddlebag Power
For those of you who may have woodworking tools: I copied Joe's excellent installation and found that a 13/16 forstner bit drilled the main hole perfectly. Since these bits are intended to be used in a drill press, I put the retaining washer with the four small bolts and used it to hold the forstner steady.
Addition: I was over at Saint K's* tonight and was showing off the installation. I had not hooked up the power end yet- just done the bag part. He pulls a cord out of drawer that hooks from the plug on the bag into the tail I use for the Battery minder (which I seldom use). Worked great! One less wire on the bike and because of the location I don't have to worry about excess slack.
(*patron saint of healthy water)
Re: ST1300-Saddlebag Power
thanks for this! that is just what i was wanting to do but wasn't shure on where and how! thanks;)
