A couple things of note. I found the instructions in post #1 to be quite helpful. I also found it useful to read all the other Rostra Cruise Control Installation posts in the ST1300 Mods section. I did the throttle cable installation last night and the one thing that would have been helpful would have been measurements on the bracket and throttle arm extension.
My first attempt at a mounting bracket (using 1/16" x 3/4" x 3/4" aluminum "L" described at the bottom of page 5) proved to be too tall, and getting at the throttle cable nut that held it in place proved to be a real challenge, even after making a shorter bracket. So I mounted the bracket horizontally, instead of vertically with the CC throttle cable to the outside of the existing throttle cable. (I'll include a picture tonight when I get home). The bracket is about 1 1/8" wide. I used a 1/4" drill bit to cut the hole for the CC throttle cable and the "U" for the mount point (and then used a Dremel cutting wheel to cut out the rest of the "U").
As for the throttle arm extension... Instead of using a Futaba servo horn, I made an arm from one side of the 1/16" aluminum "L". Again, my first attempt was too long. My final attempt was just right. I used a 5/16" bit for the hole for the throttle drum shaft and a 3/16" bit for the hole for the throttle cable mount (I used the screw, two smaller lock-washer nuts, and eyelet connector included with the CC). the holes are approximately 1 1/4" to 1 3/8" from center to center. The total length of the arm was about 1 3/4". I used the Dremel to round and sand the end of the arm so that it would not cut into the breather hose over time, but it does not appear to be making any contact, which is good. I used a total of five beads from the bead chain.
Also, I skipped making a bracket (page 12) for the Cruise unit itself and bolted it directly to the frame in the same location as described. The included self threading screw is just the right size for the hole in the frame.
I hope these measurements help someone.
The head of one of the throttle body screws in the airbox was stripped, and tackling that (successfully) took more time than I expected, otherwise, I might have made it a lot further last night.
