That doesn't look like anything I've ever seen on an ST...
I personally bought a sleeve of 10 of them from China, removed all the crappy grease they put in them and repacked them with a synthetic Mobil grease.
8,000 miles on them so far and no abnormal noises. Will check them on my next tire change.
Glad to hear it.I figured it was time to replace the flange bearings. I had just done the rear wheel bearings last fall. The wheel bearings could have kept going but the flange bearings were
shot. Nothing done on the bearings prior to this, 120,000 mi. I bought it with about 850 mi. New bearings, new tire, ready to ride. Thanks for the info Joe, everything went easy as can be.
Ok.... After reading 14 pages, here are my $64k questions: Could these bearings be one reason why some of us experience a tilt to the right on the bike when you let go of the handle bars? And, could this cause problems with the rear caliper that may cause any issues? Changing the tires yesterday, I noticed a somewhat burnt rotor and pads that were thin as paper. I knew they wearing but not that bad. Pots/pistons were a little dirty but did not want to push in well at all. One person told me to crack the bleed screw because of ABS but the fronts pushed in great. Just might be another issue. I'll check the guides again. But pumping the pads back out on the rear caused them to stiffn up to the point of too tight. IMO Partzilla.com has the best prices on OEM. Bike Bandit looks high as heck.
Squeeze the ends of the circlip together to remove it.Thanks Joe for a helpful article. Question, my ring isn't budging with pliers, does it mean it's seized or there's a trick to it? Should I be pushing pliers inward or outward after I have aligned it in ring holes?
Thanks for the help
So I have removed it and grease seems to be dry on the bearing, can I use axle grease or has to be specific grease, like moly lithium or sil glyde(rubber safe)?
As usual thank you dduelinI use a light film of axle grease on the axle itself and the outside face of that bearing. Don't forget to look up inside the driven flange that butts up against that bearing. Tap the collar out to check the condition of the two sistered bearings that support the splined hub. The two small bearings, R6905RS Honda #91052-KZ4-J21 , if original have a history of going bad in as little as 25,000 miles.
Well, note the collar is a press fit inside the two bearings.As usual thank you dduelin
Curious, if there's any other check/way I can test sistered bearings inside the flange before I pull them out? Also, should I clean and repack them with fresh grease too?
