When I first got my 1300 it pulled to the right also. I went from Dunlop tires to Bridgestone and that made a big difference. Unfortunately on my last front tire change I had to go back with the Dunlop tire and the pull came back. Go figure.
Mine was pulling to the left, and then I noticed my right butt cheak was larger than my left. Apparently I didn't read the instructions before using my wifes Buns Of Steel work out video. Within the next month or two it should be back to tracking straight again.![]()
Solo, thanks for the info.
My 05 wore the left side of the orig. BS out at 7200mi with another thousand or so to go on the right, and did have a slight pull to the right. When I called the dealer service dept. to ask sbout any issues, the service mgr. just said "road crowning". He almost said it before I finished the question. Do these guys all get trained at the same place? I have never had a Motorcycle wear a tire more on one side before, until this one.
I just installed a new michelin pr2 on the front, followed the improved procedure form this thread, took her for a ride and I think she's runnin straight. I only went for a short trip but was able to take my hands off the bars on a straight stretch. We'll see what's going on in a few thousand.
thanks for your and everyone's input.
tim
You know that explains why I keep wearing out my left knee puckTruax, You corner harder on left hand sweeps because you have better visibility.![]()
I always thought it was engine torque. Longitudinal engines like the beemer
and boss hoss tend to twist the motorcycle subtly as they apply torque to
the rear wheel. Stands to reason that if the engine is sustaining the bike at
speed, it's twisting against the frame as it does that.
Viewed from the rider seat looking forward, the crankshaft spins in a counter-
clockwise direction. That means the crankcase is pushed clockwise, which
pushes the top of the motorcycle to the right and the tires to the left.
Is this not correct?
I w as wondering if this set up adjustment has made any diference in these bikes that seem to pull to the right? my st 1300 requires more effort to corner to the left and will drift to right if I release the bars.
Exactly what I found.
My ST has 700 miles on it, original 020 tires, and pulls right.
I went through the entire set up on the front end, (good I did, I don't think my axle bolt was at 58# ft.) and the pull lessened by maybe 40% but it's still there.
I've even went in the oncoming lane no handed and still pulls right, but slightly less. Don't think the crown of the road plays much in it.
As my ST is right now I have to put my weight on my left cheek, basically looking to the left of the wind shield to go straight no handed.
A big thing on the XX site is installing tapered steering head bearings. (don't know why they still install ball bearings) I could feel a detent in the straight ahead position on my XX. I did the change, and it made a big difference, you could steer no handed with just shifting your head back and forth.
I swear I'm already picking up the slightest detent straight ahead on my ST already. Bearings seem tight, steering doesn't flop over to the stops without a little push.
It's a big job but I'll be doing tapered bearings maybe over this winter.
I do also question whether it's the weight of the shaft drive and battery being on the right side, nothing comes to mind to offset it on the left.
George, my 93 always pulled to the right until I realigned the REAR wheel. Now you can ride it no-handed with ease. This also permanently cured head shake.
