Article [13] ST1300 - Brake Maintenance - Photos of dismantled SMC
A faulty SMC, taken apart, sawn lengthways, with labelled photos and a commentary. This SMC had a brand new service kit fitted not long before it failed again.
A while ago I posted a query concerning some weird behaviour on a friends braking system. The symptoms were that in spite of getting rid of the air in his brakes and the brakes feeling absolutely fine, over a period of miles, his left SMC calliper would start to chatter and his rear pedal would go soft. A few pumps of the pedal and his rear brake would return to normal. I spent a long time with him over the phone to make sure that this wasn't an air issue and produced the article that I posted here 'Getting all of the air out of the Brake System'. He worked on the brakes with a friendly mechanic - always ending up with the same result. Brakes initially OK, and would get worse over a few miles.
In the meantime, he did some tests for me and we decided that in spite of the SMC service kit having been replaced in the last couple of years, that the full SMC bracket would be required. Last week, he fitted the new bracket and everything is working properly and better than they have ever done. Yesterday, I received a parcel in the post. His old SMC ! So naturally, I took it apart and took some photos - which I thought I would share.
Click the thumbnails to see a larger 800x600 image.
First - various views of the SMC taken from an ST1300A4 bike. Note the little drain hole at the left end of the master cylinder in the first pic - modified in the last photo which is from my ST1300A9. There are white plastic plugs inserted into the inlet port and the outlet port. I can't think why, given what I was about to do with this unit. Somewhere to keep them safe, perhaps !
ST1300A4 Drain Hole.jpg SMC-ST1300A4-02.jpg SMC-ST1300A4-03.jpg SMC-ST1300A4-04.jpg SMC-ST1300A4-05.jpg ....... ST1300A9 --> ST1300A9 Drain Hole.jpg
Prior to removing the circlip to release the piston from the cylinder bore. The circlip is particularly difficult to access - even with the unit off the bike on the work bench. The lack of light and rubber boot and the plunger being in the way hinder things considerably. Note that in the last photo, I gave up and removed the bracket and the boot in order to get a better view. This should not be done unless a new piston service kit is to be fitted. The securing bolt is set to the correct length at the factory, and the correct length is critical.
SMC-ST1300A4-05.jpg SMC-ST1300A4-06.jpg SMC-ST1300A4-07.jpg SMC-ST1300A4-08.jpg SMC-ST1300A4-09.jpg
In the next sequence, the piston has been removed. The photos show the amount of crud that has built up behind the boot. This unit was greased behind the boot and the drain hole was kept clear. Nevertheless, this is a mess.
SMC-ST1300A4-10.jpg SMC-ST1300A4-11.jpg SMC-ST1300A4-12.jpg SMC-ST1300A4-13.jpg SMC-ST1300A4-14.jpg SMC-ST1300A4-15.jpg
Here I have turned the bracket over and removed the inlet port cover plate, which is retained with 2 small bolts, which have thread lock applied. Underneath is a rubber ring and a small white cylindrical cartridge - the SMC inlet port valve and the relief port
The Inlet port valve and relief port cartridge. both sides have a very fine mesh gauze. I haven't dismantled it at this point. The last two photos show the inside view of the larger inlet port hole and the very tiny relief port at the bottom of a small depression.
These photos are just for info for anyone who is interested and may find them useful.
First the service kit. In fact, this is the very service kit that was installed in the SMC just two years previously. Clearly, something went wrong - this SMC should not look like it did after only 2 years.
And that little cartridge. The white cartridge duplicates the holes for the inlet port and the very tiny hole for the compensation port. The Inlet port has a spring loaded one-way valve in it, allowing fluid to flow in through the inlet port, but not allowing it back out - except through the compensation port. I am not entirely sure of the reason for this. One suggestion has been to aid brake bleeding - but there are no bleed points on the SMC, and the primary seal acts as a one way valve, so there would be no need. My feeling is that it has something to do with the inlet port being connected directly to the centre piston of the left caliper - perhaps to prevent any backward pressure from applying the front brake. But that is speculation, and I cannot see how this would arise, unless the SMC seals were failing.
And finally, evidence of what I did with this broken SMC !
Sawn lengthways (almost). The narrow end is as a result of having to saw down the bore at a slight angle. It clearly shows the the inlet port and compensation port, and the build up of corrosion at the pushrod (left) end.
And a different view with the components installed. The positions of the two ports behind the piston are clearly marked - the consequences of the piston not being able to return fully to its resting position, are that the primary seal, blocks it off, prebenting it from releasing pressure.
So what was the fault with this SMC ?
Well the metal 'cup' at the end of the piston which is closest to SMC plunger was a very tight fit inside the cylinder bore. There was no build up of crud just inside the bore - in spite of the amount on the outside, and the metal cup didn't feel rough. When the piston was pushed inside the bore, it met with resistance once the secondary seal was inside - the metal cup was tight against the sides. When it was pushed in further, it eased up and would return part way under spring pressure.
This sounds like the classic situation which often results in the SMC not returning and causing the back brake to lock, but this wasn't the case - on the contrary, the pedal lost pressure.
As it stands at the moment, I reckon that the cylinder has had a slight knock and has become slightly oval. Although the secondary seal was doing its job, the fluid was able to move back past the primary seal, resulting in the long pedal and chattering SMC bracket. My diagnosis might be wrong but its a working theory.
[Edit]A separate link here shows pictures of a brand new SMC unit for a 2008-onward ST1300, including a measurement for the plunger.[/Edit]
Re: Photos of dismantled SMC
Very nice! Thanks John!
I seem to remember someone having the same issue a while back and discovered the bore was not perfectly round as well. Maybe V8-Stan.
I had an out-of-round piston by about .25mm that was enough to bind the piston in the bore.
https://www.st-owners.com/forums/showthread.php?132690-Another-SMC-repair&highlight=
Now have about 50K miles on the repair with no problems.
Also if you need to remove the bracket and boot ( quote: " removed the bracket and the boot in order to get a better view. This should not be done unless a new piston service kit is to be fitted. The securing bolt is set to the correct length at the factory, and the correct length is critical.")
measure the protruding end of the bolt or count the turns to remove the nut, so you can reset it to the original length .
Great info, any idea how to prevent this? Can we keep the "drain hole" clear? Which hole is the drain hole? Lol. No really, which hole
Thanks for the very detailed info. I hope never to have to put that information to use, but if I do... I know where to look.
Great photo report, John. One thought occurred about your friends smc,, is that it had been repaired/serviced prior, as indicated by the presence of the silicon grease. I think brake dust and moisture combine to create this oxidized muck that then dries out somewhat on sunny days. Better shielding, in addition to the oem rubber boot might help keep more contamination from being caught up in the rather open cupped upper end of the smc. Might be worthy of some thought, given your typically rainy rides,,, Cat'
John, thanks for posting the pictures. Looking at the picture of the piston, it appears that the rubber bits have worn down to allow the metal piston body to come in contact with the bore (see shiny wear spots on the fins) several things to be at work here, the grime and crap on the push rod head and around the end of the assembly, air in the system, the rubber not keeping the piston centered perfectly in the bore, the spring getting weak and taking a set, also would allow the piston to not be centered in the bore, and could cause it to cant or bind etc.
Every bad SMC I have taken apart, I have always found wear on the top inside of the bore. It may only appear as a dark shadow or ring just inside the bore, but once measured, it revealed that the bore was no longer true.
Once again, thank you for posting such great pictures, and going the extra mile to help the other members, you are a true gentleman.
Larry
I am no longer worthy :bow1:
From this day forth, You will be known as the ST-Whisperer of Ilkley, West Yorkshire.
Brilliant, just brilliant
All this just to activate the 2 outer pistons on the rear caliper.
Also, all of this plumbing comes from the rear master cylinder.
I had a hard time at first thinking this Secondary Master Cylinder is mounted up on the front fork, so the brake fluid is from the front right handlebar fluids, BUT the fluid is from the rear pedal master cylinder fluids.
Very informative , Jeff !
That is a lot of engineering and a bunch of potential fail points..
Wow. Just WOW! Great article and amazing pics and diagram.
Brilliant indeed!
I may have to turn the :call: white courtesy phone over to John as well :wave1:
The best articles and pictures I've seen.
My hats off to you Sir :hat1:
jfheath, thanks for all your info. My ST sufferred the dragging rear brake. It did normalize after the bike sat for a couple of minutes. Anyway, I was trying to activate the smc by hand and it won't move. Could that also be causing a rear brake dragging?
Thanks jf! I've been reading a bunch on this forum and the GL forum. I think I'm going to go ahead and order a new SMC and go from there. I am thankful for you and all the knowledgeable folks on this forum.
Before you do that, call me on the white courtesy :call:
I have a couple questions for you.
