Article [13] ST1300 - LED Mirrors - Now you get noticed with STYLE
Well, my farkling has begun.
I did the LED's on my mirrors yesterday. I commend you on your instructions. For the life of me I could not find a 1/4 watt 120ohm resistor anywhere. Radio shack didn't have them so I went to Fry's Electronics and found two 5 watt 120ohm resistors. They're quite a bit larger than the ones you show but they work fine.
I also installed an auxiliary fuse block, that works off of a relay, and wired in some heated grips to the block. I'll be adding 2 powerlet sockets (http://www.powerlet.com/) just below each glove box next week. In addition to their sockets I ordered the adapter kit which will work with my heated accessories yet to be purchased.
Finally got around to doing this mod. It doesn't happen often, but I'll never forget to turn the signal off again!
My variation:
I chose to fill in most of the little vent slots in the mirror with amber LEDS, 10 per side.
I didn't want to drill the mirror slots, so I chose to modify the 3mm leds by sanding them down to 2.25mm on 2 sides such that they were oval shaped. These pressed into the slots nicely.
I then split the 10 into to groups of 5 and powered them seperately off 170ohm resistors. Coated over with quality RTV to waterproof and provide strain relief.
Very pleased with the results!
attachment.php
Installation pics:
attachment.php
attachment.php
Schematic:
attachment.php
FWIW, If anyone is interested in a "kit", I have enough parts left over to make up a couple more. It would include the modified LEDs, resistors, fast-on connectors for the signal wire, and a ring terminal pigtail for ground. You'd have to solder it up. $25 shipped US.
Ok I am doing something similar. I like your guys idea but want the LEDS facing out and not back.. I am using a LED strip and going to put it on the edge of the mirror housing, facing out. Using a Mode Electronics cut to length SILICON ENCAPSULATED SERIES LED STRIP part #55-73300R-0. 12 Volts right to the solder points on the strip, as the resistors are integral to the strip, no need to add any.
Part
Number Length [m] LED [PCS] Material Type Emitted Color Lumen/meter Dominant Wavelength [nm] Color Temperature View Angle
55-73300R-0 5 / 300 AlGaInP Red 120 625 n/a 120
As this is an old thread I will put pictures on as soon a s I am done.
So now you know...:p:
Can't wait to see what you do, Gypsyh. I did the same thing as this thread outlines. You can, however, cheat the angle a bit. I drilled out my holes with the bike and drill level and then out to side a bit. I can't really see the light from my seat when I turn the blinker on but when you're behind and off to the blind spot, they are seen at their brightest.
Don't forget to post your pics. Good luck with your project.
I did a mirror install this weekend. But did a single 5 led strip in the side. Use the 2.2 v 20ma lights from superbrightleds.com
You can get the LEDs and the resistors from them, $.60 each, $0.54 if you buy 10. Then get a pair of 180 ohm resistors for $0.14 each. So a total of $5.68 in parts.
In place of sanding the bodies I opened up the hole on the mirror with a 1/8" brad point bit. The hole was then reamed from the back with a slightly larger bit, 11/64 I think. Didn't go all the way through, just in enough to get the base of the led in and let the nose poke out the front. Slide in each of the leds and let the friction hold them in place.
Bought a pair of SAE connectors for each side, think a $1.25 for each pair with 18 gauge wire. Wired those in to disconnect when the mirror covers come off.
Great farkle.
Thanks guys!
Ok I think I am done....for now. Like I said before I wanted the LED's facing out wards. I connected the wiring into harness outboard of the wiring connectors 1P/2P coming from the upper cowl, that way it is easy to remove the mirror cover. I think I am happy with it. Let me know what you think.
Be gentle.....:eek::
Just ordered a set... I've been wanting to do this for a while... I had a set that were made for the Gold Wing mirrors, but they were a one piece LED that stick to rear of the hole flange on the mirror mount, and it was a pain to get the mirror cover back on... Looking forward to trying these instead... :)
DakotaJoe,
Thank you for posting this thread. I going to take on this farkle with the twist that playfair added (x10 3mm LEDs). I was wondering what MCD (intensity) value your LEDs are? I'd like to go with the 3mm LEDs, but keep the brightness/intensity (mcd) of your original project. It's been a couple years now and manufacturers are making brighter LEDs in smaller packages.
Thank you in advance,
Chromy
20130223_110559 (640x480).jpg20130223_110618 (640x480).jpgWell, I took this project on and as others commented it only took about twenty minutes.
Went to my local Radio Shack and picked up everything pictured for less than 12 dollars.
20130223_124713 (480x640).jpgHere's the result. Bright enough from behind, but not too bright from the rider's position due to the 30 degree LEDs.
I'm planning on installing red running light LEDs below the turn signal ones in the future.
