ST1300 Heated Grips
On this side of the pond we would call that 'potting'.
Yep. In the service a lot of our gear was 'weatherproofed by potting in and putting in a somewhat water resistant contained. One dead always dead. *Kind of cool to pull apart something and have a rectangle/square/whatever. Usually it was opaque but a couple times it was amber and you could see most of the components. Pretty cool.
Good point!
According to the service manual, the charging voltage shall be between battery nominal (12V) and 15.5V @ 5000 rpm. Quite a large range, indeed.
Note that I would be much more worried if I saw 15.5V on the battery terminals. Ouch! Here goes the battery and bulb life…
Before putting the bike away for winter, I did a quick voltage check with the engine running. I installed a small dedicated 12V voltmeter to monitor the system voltage, (the voltmeter was checked and confirmed for calibration) placed in such a way that I could see the reading during riding, but not connected directly to the battery terminals. It was connected to a similar circuit has for the grip controller.
It was quite steady @ 13.7V (±0.1V), except when the flashers were activated. Then it was all over the place.
First scary symptom!
The rest is described in the previous post.
Understood that I have to push the investigation further. Mainly, checking the battery voltage @ 5000 rpm.
Waiting for a relief in cold temperature to bring the bike out for a quick test cession, in the car shelter…
More to come...
