That is an awesome light BUT
Totally sold out @ Cyclops, estimate End of March ! Worth waiting for ? You had Ultra ?
Other places have it.
Now available in the original version or the Ultra version. The original uses the front two emitters for low beam and then switches to the rear two emitters for high beam, The Ultra uses the front two emitters for low beam and then runs all 4 emitters on high beam at a reduced wattage. wattage...
ktmtwins.com
Cyclops H4 LED Gen 10.0 Headlight Bulb 10,000 Lumens (that’s NOT a misprint) This bulb has 4 emitters: 2 for low beam, 2 for high beam There’s 2 styles available: The Standard version (which we no longer stock*), and The […]
bestrestproducts.com
Do you have an Honda ST? if so this optional base will be plug and play
H6 base for Honda ST [+$2.00]
Worth getting ?
Yours burned out after one season but you liked them so much that you bought them again. Says a lot. Thanks tnman.
Pricey @ $180
Upgrade To Ultra 10.0 [+$10.00]
One year warranty isn't very good for an expensive light. The cheap ones have that.
JJ
