My time is at a premium with working full time (Self-Employed at 70 Years Old) and (4) Motorcycles to configure with my many Modifications. So I bit the bullet and ordered (2) GPI's (Gear Position Indicator) from following provider:
http://www.acutrac.co.uk/digital-gear-indicators-23-c.asp
http://www.acutrac.co.uk/digital-gear-indicator-dg8-with-cool-blue-display---30100-67-p.asp
My contact point was David and he has responded to my several questions very quickly.
My Goldwing 1800 has the VEYPOR Analyzer that includes a Gear Position Indicator and my Burgman Executive has an Electronic controlled CVT (Continuous Variable Transmission) that when in manual Mode shows (5) Five Simulated Gear Ranges plus Overdrive.
I am spoiled with the GPI on these two Motorcycles and had to have similar on my 2008 Nomad 1600 with Drive Shaft and my White/Black ST1300PA (Police Special). This UK Supplier seems to have an excellent Product and I look forward to installing their GPI's.
They also sent me PDF Documents showing their Hookup and Training Procedure. I will attach these PDF's and also copy below my correspondence back and forth with them.
Hi Ron
I sent a PayPal money request earlier, have just resent a reminder.
David
AcuTrac Ltd
6 Towergate Business Pk
Andover
Hants
SP10 3BB
United Kingdom
Tel; 01264 310007
www.acutrac.co.uk
Registered in the England & Wales.
Company Reg Number 05868263
Registered 10 St Ann St, Salisbury, SP1 2DN
________________________________________
Hi David,
Again thanks for the fast feedback ? I will now place an order for (2) of the Digital Gear Indicator DG8 with Cool Blue display ? 30100.
Please send PayPal a Money request as you have stated and I will respond ? I did a conversion and it looks like about $150 Canadian each plus shipping.
Warm Regards,
Ron
Ron Amos
Cell: 613-291-7730
Nerds on Site
Orleans, ON, Canada
www.NerdsOnSite.com
What would it cost you if you lost your data? Try a Free 14 Day Trial of Nerds Backup today. Get your first 2GB of storage for free.
http://www.nerdsonline.com/ramos1
Hi Ron
You can?t really alter it. We would take a White LED ? they are more expensive than the normal Red LED?s ? and put a filter between it and the outer fascia. So every time you want to change the colour you will have to remove the fascia (which is self adhesive so you will need a new fascia) and change the filter and do it again. We normally filter the White ones with a smoked filter, so they look pretty much all black when off, but the white shines through quite well. You also need to consider that all LED?s need a filter ? it improves the contrast so much. Blue is fine unless the sun is shining onto it (ie; you?re riding with the sun behind you); it?s just the way the eye looks at that part of the spectrum.
David
Hi David,
Now you got me thinking as yes I did want the Blue 30100 but as you caution it washes out in direct sun light.
So the best alternative would be the Digital Gear Indicator DG8 - Custom Colour ? 30113 Model if the Colour can easily be changed by the Rider (Me) to suit the time of day. Your WEB Site states the following:
This DG8 Digital Gear Indicator is for a custom-coloured display. We will take a White display DG8 and filter it to the colour of your choice. Match your bike, your partner's eyes! Whatever. Auto-Dim for night-time use (Note! If the display is bright enough to see in the day, it's then too bright at night). Truly universal. The market leader of gear indicators. Plug in looms available - see related products.
Does the We will take a White display DG8 and filter it -- mean only you can do this or is that a miss-print?
Again Thanks,
Ron
Hi Ron
I can do a deal straight from PayPal ? I?ll send a PayPal money request but you will need to tell me the colour of the displays you would like- Red White or Blue are the favourites. A word of caution ? everyone goes for Blue because it so pretty, especially at night. But it ?washes out? when the sun is on it. White is stunning as well.
The unit is completed encapsulated so water isn?t a problem, not even for the switch at the back, as the back side is sealed as well.
Size is 26 mm wide, 36mm high and 22 mm deep.
The DG8 has a lead about 300mm long from the housing, ending in a 5pin mini din. A 1.5metre extension lead is also included in the kit.
David
Dear Sirs:
Thanks for quick Response ? I will likely order (2) of the Blue LED Gear Position Indicators but need to know their dimensions so I will know where they can be mounted. Since no Plug in looms are available for my Motorcycles can I attach my wiring directly to these units? Is there exposed wiring or terminals to attach wiring?
Also are these units waterproof as they will be exposed to the weather? I can see by your supplied PDF?s there is a hole for the learning Key that could be plugged of covered with Silicon Seal once they are programmed.
I live in Ottawa, Canada (Orleans is part of Ottawa) and your shipping only shows USA? I can pay with PayPal and since I will be purchasing (2) two do I get a break in shipping cost?
My Address for shipping estimate:
Ron Amos
6388 Nuggett Drive,
Orleans, Ontario,
Canada K1C 4X9
Thanks,
Ron.
Hi Ron
The DG8 works by comparing the speedo and tacho signals, effectively learning the gear ratios of he motorcycle. Thanks for the not eon the broken link ? I?ll get that checked by the IT guy.
The DG8 will work well on both of your bikes but it will be a solder job ? there are no plug in looms for those bikes.
David
Sir:
I like the Item listed below but need to know how to connect it to my Honda ST1300 Model Year 2006 and to my Kawasaki Vulcan Nomad 1600 Model Year 2008:
Your WEB Page
http://www.acutrac.co.uk/digital-gear-indicator-dg8-with-cool-blue-display---30100-67-p.asp states the following:
The DG8 Digital Indicator is the market leader. This DG8 Digital Gear Indicator is with Cool-BLUE display. Will learn up to 8 gears. Auto-Dim for night-time use (Note! If the display is bright enough to see in the day, it's then too bright at night). Truly universal. The market leader of gear indicators. Plug in looms available - see related products.
Will learn up to 8 gears ? how is this done?
Truly universal ? Will it work on my ST1300 & Nomad?
Plug in looms available ? cannot find needed looms on your Web Site?
Related products ? Is this supposed to be link, if so it doesn?t work?
Regards,
Ron
Above correspondence took only 24 Hours and to complete my Order!
Will now attach the PDF's -- Purpose in sharing this INFO is to provide an alternative for the many ST1300 Owners who are not able to assemble the fantastic GPI Device that (pdfruth) has provided the research for and shared details to build.
At today's exchange Rate my (2) GPI's shipped to my Home costs a total of $255.27
Northern Dancer,
Ron
