I’ll contribute to the cost if anyone would take the lead on that.
Pete
Pete
I'm not done yet... This weekend!
attacking th slave Cyl. yup she need an exchange. scoring on the inner wall resulted in a new assembly. thanks for the information on the new replacement unit! I kept the speed sensor in during the removal. While i'm here...I probably look to get a longer shift shaft to go GP
Any experience a torn lifter rod torn seal? What the part # and can this be replaced from outside engine installed in the bike?
looks like it may be #14 on https://www.bikebandit.com/oem-parts/2006-honda-st1300-st1300-rear-crankcase-cover/o/m2529sch414338
NOW, is this installed from inside the engine or outside of the engine???? inquiring minds want to know. dow does one go about working this bugger out?
Thanks Pete for this great how to article. I was about to start the riding season this week but I lost all resistance in my clutch lever while the bike was siting in my garage. I checked the fluid level and it was 1/2 empty... Checked the master cylinder and didn't spotted any leaks. My guess is the CSC at this point. Just ordered the parts and will do the job this long weekend.
Will keep you posted.
Cheers
Don't for get the clutch shaft seal! ST1300-clutch-push-rod-lifter-rod-seal-replacement
I haven't order this one... Do you really have to replace it?
Not as daunting as I imagined removing the CSC, I found it quite an easy job.
Difficult jobs -
Getting the 8mm socket onto the inboard bolt and then only having a couple of turns before the wrench fouled, easy enough to undo the rest of the way with fingers.
Removing the old CSC, I had to use a "Persuader" as it hasn't been touched since new in '02.
Now to install the new one.
