From your description, it sounds like you may be hearing the counter balance adjusters out of adjustment.
This would make alot more sense than your clutch bearings etc.
Also, do you have any coolant leaks? If coolant is spewing out the overflow tube below the front of the lower cowl you may have lost your water pump mechanical seal or bearing.
This would also sound like a high pitch noise if the prop were hitting the cover etc.
