Just did this on mine. Got one of those handheld vacuum pump kits. The adapters that fit on the bleed nipple are rubbish. I just used a piece of hose that was a tight fit. Worked way better!When I did mine, I used a hand-held vacuum pump. I first used it to empty the reservoir, cleaned it, added fresh DOT4, then attached it to the slave cylinder.
Then I opened the bleeder, pumped repeatedly, topped off the reservoir as needed, and kept going until the fluid coming out was as clear as the fresh fluid.
That's true. Loose fit, leaks air. Fortunately, that's not a problem with vacuum.The adapters that fit on the bleed nipple are rubbish.
Using a vacuum to flush and bleed your clutch will not get the crap out if your clutch slave cylinder.Just did this on mine. Got one of those handheld vacuum pump kits. The adapters that fit on the bleed nipple are rubbish. I just used a piece of hose that was a tight fit. Worked way better!
Maybe not but the old fluid in there definitely needed changing. I got rid of the heavy junk in the master cylinder first.Using a vacuum to flush and bleed your clutch will not get the crap out if your clutch slave cylinder.
You need to work the lever to get the CSC piston to move.
Yes, but most people and shops don’t work the lever or even think about it.The use of a vacuum bleeder does not prevent working the lever to pressurize the system and move the piston. The two are not mutually exclusive. It's all in how the tools are used.
If you had heavy sediment in the master cylinder housing, you can bet that there is much more in the clutch slave cylinder still sitting there, that is going to move around and circulate through the system again.Maybe not but the old fluid in there definitely needed changing. I got rid of the heavy junk in the master cylinder first.
Thanks Larry. If it changes color quickly, I’ll do another flush. It’s pretty easy to do now with a vacuum bleeder. I’ll keep an eye on it. I don’t mind doing a few flushes to clean it out. I would assume the new fluid will lift some of the old stuff and redissolve it. That means I can pull it out over time.If you had heavy sediment in the master cylinder housing, you can bet that there is much more in the clutch slave cylinder still sitting there, that is going to move around and circulate through the system again.
Don’t be surprised if you fluid turns color again quickly.
Don’t laugh, some of the bikes that have come through the garage have probably been serviced like this.
lolI'm tired of arguing with stupid people
That makes it a procedural problem, not a tool choice problem.Yes, but most people and shops don’t work the lever or even think about it.
As the saying goes- It is a poor mechanic who blames his tools.Having used vacuum pumps, air pumps, reverse bleeders, loop methods, and such, I still find that you will get the most amount of air out of the system(s) using a simple check valve, with the correct procedure.
I have proved this many times, by having training events where master mechanics have been allowed to use their vacuum pump systems first, and then shown how much more air was removed with the simpler check valve method.
Use whichever you thinks works best for you, but just don’t let someone like me bleed it afterwards or it may embarrass you.
