Article [11] ST1100 - Timing Belt Replacement
2nd attempt failed as well, hopefully it'll last another 10k.
For a bolt that's supposedly fastened at about 27Nm it sure does not like to let go :-(
Are you using good quality tools, or cheap ones? If its the bolt I think it is, I'm surprised you could round off the head if you were using a quality tool of the correct size.
(2/1/2003)
attachment.php
The top fairing doesn't have to be removed for the job.
attachment.php
Draining the radiator so it can be removed.
attachment.php
Radiator removed. The timing belt cover needs to come off next.
attachment.php
As Jeff Bertrand said, the cover can be removed with a 'little' cursing and prying without removing the clutch cover. Prying with a screw driver as shown just 'barely' allows the cover to pass between the clutch cover and the bolt seen in this picture. I'll have to Dremel the cover as Jeff recommends to make it easier next time around.
attachment.php
The old timing belt about to be removed.
attachment.php
It's a <little> hard to get the timing belt out with the clutch cover still installed, but a pair of needle nosed pliers did the trick for me freeing it from the driving pulley, (the lowest pulley shown here).
attachment.php
Timing belt removed. The driven pulleys on the cams moved about 1/2 of a tooth when the belt was removed.
attachment.php
New belt in place. You start at the driving pulley, the the right driven pulley, (the one on the left in this picture). Then to the other driven cam pulley, then around the last smooth pulley.
attachment.php
You can just make out the punch mark on the driven pulley lining up with the mark on the case.
attachment.php
I was pretty lucky and got things all lined up on the first try. The right driven
pulley shown here moved about 1/2 a tooth clockwise during the removal/install of the belt, but lined right back up when the tensioner was let loose.
attachment.php
The left side driven pulley all lined up. The 'up' indicator on the pulley points to the tooth with the alignment mark that should point to the mark on the case.
attachment.php
The manual tells you to put the retainer back on before you crank the engine over
about 4 times. This prevents you from being able to see the timing mark. I just put
a little black mark on the retainer and lined it up with the timing mark before I
tightened the bolt. This allows you to make sure the timing remains correct.
attachment.php
You can see the Dremel job I did to the cover , (just below the driving bolt), per
Jeff Bertrand's instructions. This made it much easier to re-install the cover.
There are some great instruction on replacing the timing belt by Martin Brunner,
(STOC# 637 PanEuro# 42), over on John Parkers web site.
Pertinent link to Mike Martin's web site. Good stuff!
Great photos and information. Going to change my bikes timing belt this week. ST is 35 years old,60.000 on the clock and the bolts and fasteners have not been touched since the Honda factory installed them.
Wish me luck, I’m going to need it.
I’m sure you’ll be fine (I’ve done 2 of these jobs, never having done a TB in the past)- take your time and be meticulous - since so much bodywork comes off, label everything (I used labeled Ziploc bags for all my hardware). I had each bike apart for a week, did a little each day, and all was well.
