In my past days, I was a pretty serious 'wrench' on car engines - building, 'enhancing' them, etc. so I'm pretty aware of basic principles of ICE engines.
Swapping an engine (now that I know how to get it back in) is not really that big of a deal compared to trying to pull a head on a ST1100 in place.
I'm past the point of 'debugging' as there is oil on the end of one or more of the plugs after all the 'treatments', fresh gas, etc.
Oil does not get into the compression section of a cylinder unless the valve guides are bad, the rings are worn/broken or there is a leaking head gasket ...
...unless a space alien slipped in while I was gone and removed the spark plugs and shot oil in the cylinders.
None of that is easy to fix and none of that is easy to find unless you do some serious tearing down of the engine.
The engine is smoking really bad and getting worse at this point.
I can spend the next six months trying to figure it out or I can swap the engines and get her back on the road.
At this point in my life, getting her back on the road as soon as possible is more important to me than figuring out the 'why'.
Riding time is something I know that sooner or later may come to end for me so maximizing it is my priority while I can.
I hope to leave this world riding right up to my end, but that is something I do not have ultimate control over.
Also, having had over 20 different surgeries, I realized a long time ago that the next could be my 'last' one.
I have learned that
"I can always make more money, but I can't make more time."
So the 'shortest' time path with the best probability of success is what I look at to determine what I will do.
I learned something a long time ago in the computer business - you get it working and worry about the 'why' when it is convenient.
I may stumble upon something as I do the 'removal' process - but I don't hold out a lot of hope.
My hunch at this point is that (and I've seen this before) the 'wear' process from the PO and me differed greatly and caused the issue.
I've seen that on both of the ST1100s that I purchased used as I run them pretty hard.
On one, the oil pump started failing and I had to have it replaced - very unusual for a ST1100.
I do appreciate all the concern and the suggestions (and I've tried some of them) but I've got three rides in the next 4 weeks and I'd like to have this one up and running for at least one of them since it has really good tires on it.
