Alright, I just dug out my ST1300 test ride report from 2004 and translated it...
Here it goes <flame suit on
First impression: where is the vehicle please?
If you stand next to it, it actually seems relatively puny despite the TC and suitcase.
If you sit on it, you have far less fairing in front of you than on the 1100; no wonder that they have problems with attaching accessories, where to put them?
From above / behind the wide main tank looks downright clumsy, the 1100 comes across slimmer, longer-stretched.
Ergonomically, I've already had problems with the clutch and brake armature, I would have to turn both down further,
but it doesn't work on the handlebars, so both wrists are bent a little upwards, and it soon becomes uncomfortable, especially on the clutch hand.
Seat:
set on the highest notch it really pisses me off in the truest sense of the word: it squeezes your balls...
set it lower later on, not much difference...
Panorama of the rearview mirrors takes some getting used to, these slit eyes are not really in the 16: 9 format.
No light switch! hardwired, ignition on and the Christmas tree is up, once ign is OFF, no position light nothing.
Nor is there a PASS switch, no longer a standard Honda switch pods...
Foot pegs: somehow the distance between driver and passenger pegs seems very small, my pillion will probably get stepped on her toes quite often...
Really screwed up is the accessibility of the side stand: if it is down, the driver's peg is in the way to fold up; if it is up, the heel of my size 13 boots always
hits main stand and side stand at the same time, and to fully unfold the side stand, the driver's peg is in the way again; badly sorted there....
I can't yet find what should be so extraordinarily better about the gear-box; ok, shift travel a bit shorter, the lever is too high for me, the gear box is cluncky
in comparison how pleasantly and easily the gears slide into on my 1100...
The steering is somehow nervous, no resistance, the vehicle nervous, no way of just cruising casually with the right hand on the handle is not, gets all over the lane ...
Feedback from the steering is also strange, first corner, the moped constantly tries to straighten up, like that there is something wrong with the tire pressure;
Fuel gauge faulty: when driving away it flashes on reserve, shows ~ 40 remaining kilometers, but I was able to fill up just 19.8ltr ...
filled to the brim, but the clock is still missing the last bar on full ...
Refueling is really tedious, can't just hang it in, fix the trigger and you do something else, the nozzle doesn't fit in because the tank bottom is 4cm below the opening,
so you'll soon suffer a cramp holding the tap there...
I drove through the city, practicing braking and clutching, testing handling. Tire pressure now ok, hence the typically hard rolling behavior of radial tires.
Steering still somehow indirect, in corners constantly the feeling of slipping over the front wheel ...
Generally sensitive to longitudinal grooves, crossing whitelines, casting compound... by no means as unimpressed and steady as the 1100, have the feeling
that in particular the rear tire follows an edge of a white-line for quite a while before it finally goes over it....
Noise from the engine is just terrible, not only this constant dentist's drill, but also the eternal rattling and vibration when accelerating after switching gears,
bounces really viciously right into the seat. Let's see if it's up to me (throttle grip) and that it will continue tomorrow and the day after tomorrow.
Brake already very spongy, zero feedback, you grip like in foam rubber, first nothing happens, you grip harder and suddenly it claws into the asphalt,
no advance warning, no defined pressure point (note: I drive non ABS-ST , there is pressure point like hard rubber block, grip like directly on the brake pad,
very comfortable to dose).
Sure: the deceleration is there, delayed however...
Same on the clutch, always the same pressure from front to back on the lever, no signs of a gripping point; promptly stalled it twice (has not happened to me in a long time)
The heat distribution is funny (no side deflectors installed): you can't feel anything at the intersection (but you can hear the fan running all the time, engine suffocating under the fairing),
not much to sense while riding slowly; but when you hit like 60kph very hot air from the sides suddenly hits your calves and lower legs.
Another impression: they don't see me !!
No $h!t, I didn't have so many idiots running a stop sign or exiting from parking spaces right in front of me then on that 1300; even pedestrians just ran quite into me
I guess that the stance and especially the headlight of the 1100 gives a more distinctive, brighter profile and you are therefore better noticed.
Horn works in any case, used it several times, but since they'd omitted the PASS button no other signalling avail...
Parking is easy (apart from fiddling with the side stand), it actually feels a lot lighter than the 1100.
The one-hand operation of the case locks / lids is not that bad, if only the cylinder and lock wouldn't jam so terribly;
The key barely goes in, the lock sticks so hard I'm afraid I might break the key ...
Next day with pillion aboard:
I don't need a handlebar riser, for me it would have to be further forward and lower, as I have now slightly bend elbows with pillion behind, which is pretty inconvenient,
to absorb the/her weight when braking is also very uncomfortable; I prefer to have fully stretched arms, more direct contact with the vehicle.
The pillion also complains about the ergonomics:
Although the sternum is in contact with my back, the usual contact between your knees and hands and my thighs just doesn't work out; giving her insufficient
information about my movements while driving / maneuvering, and she doesn't see past my helmet, unless she tilts her head until her ear is on her shoulder
(which of course, it doesn't work with a helmet and shoulder protectors ...), she feels generally more cramped in than on the 1100 (so do I, for the above reasons ...)
Furthermore, she has a problem with pegs/panniers, the case tips protrude so far forward that her calves are pressed against and she cannot put her feet properly on
the pegs as usual, which means that she can not support herself properly when accelerating / starting / braking and always has the feeling that she is now thrown down behind.
Somehow the position of the feet does not suit her at all, her toes fall asleep very quickly, we took several breaks, changed our sitting positions, but stayed that way until we returned home.
What are these aluminum ears behind the pillion pegs used for, with the best will in the world she can't reach them with her heels ... maybe when the panniers are off? But who does that...
She also complains heavily about the rear seat rim + carrier stay pressing at her coccyx, not happy... seems the 1300 offers a lot less space...
Instrumentation:
for some reason I have slight problems reading this speedometer, it's a bit confusing.
The digital display would be better in multi-colored gradation, clearer, faster and easier to identify.
Also is the glass way too reflective, most of the time I only see a glaring, gray surface as the sky reflects in it... but can't decipher and instruments... kinda dangerous IMHO...
The indicator controls and other warning lights are as well simply hidden away from me... obviously a bike made for dwarfs rather...
The fuel gauge definitely has a problem, with only 100km traveled a reading of 1/2 simply cannot be right! Switching to reserve with ~ 70km remaining range at 270km also
seemed a bit too pessimistic to me, when the remaining range of ~ 50km at 300km was displayed on the trip-meter, I began to ponder where the advantages of EFI should be,
because I had certainly not raced the ST1300... so why is she guzzling like that?
Mirrors:
So with a pillion, any view to the rear has suddenly vanished, you just can't see another motorcycle behind you anymore (that you lose it again later is another story
I also find the clutch and brake levers not being anodized quite annoying, that shiny aluminum always sparkles around in the mirrors, simply irritating.
And that the mirrors even start to vibrate from 4,000rpm upward, fully hazing the view, astonishes me in that price category ...
Windscreen:
Sorry folks, I've tried a few things, set high it's obstructing the view, set low I've full draft on my helmet causing the visor to vibe distorting my sight... not happy ...
There is also much more fluttering around the jacket sleeves.
The passenger also reports that she's experiencing way more buffeting then she is used to...
Engine:
So the internal whistling with this this hard, astmatic rattling when accelerating make me nauseated; the first sounds like a dental tool all the time, the second like when
someone gives full throttle on a KTM thumper...
In addition, it vibrates
very hard right into the seat (which is even more uncomfortable because of the above-mentioned bad pressure point to the crotch);
Of course, I cannot judge whether the demonstrator's engine has not already been abused, or is simply badly adjusted...
The thing has pull, it zooms away really well when passing, one can theoretically jump around like a racing bike.
The clatter and rattle on the other hand, as well as the vibrations spoil the fun of opening her up to let her rip, its just tiresome...
No one gets a touring/travelling vehicle to then have to listen to engine noises...
Load changes are harsh however... that EFI is defenitely not my thing...
The engine of the 1100 is notorious for its
unspectacular performance, but I find this demo bike disappointing, I had somehow expected more...
Transmission:
Shifting is ok, just required way too often, IMO are the gears too short, the constant hacking 2.-3.-2. when cornering it is soon annoying (also due to the engine noise)...
Where I drive sporty in 2nd & 3rd on the 1100, its 3rd & 4th on the 1300 to have a more smooth pace (whilst lugging the engine though...)
Steering:
It is essential to differentiate to what extent the tires play along here, the steering seems to me to be very indirect, spongy, just can't find a line, I get no feedback from the road
or about my leaning angle, I just can't seem to get a nice ideal curve line with the skittish behavior and handling of the 1300... always have the feeling it is under-steering, sliding
over the front tire, even with only a slight lean angle...
Even on a straight piece, it constantly wiggles and dances in the front, even when slowing at traffic lights, you suddenly wiggle the handlebars to stay straight, an effect that
I don't know, I'm not used to on the 1100, it just slows and stops with zero tugging on the handlebars, steady as she goes captain ...
Of course is the 1300 is maneuverable, hardly requiring steering forces, short wheelbase and steep steering head are definitely noticeable, you can throw it around corners
as if there was nothing (and immediately loose the VFR that believed it can hide behind the taillight and in the blind corners caused my pillion's knees...), with the engine power
the thing is moving properly, leaned over well and boots scrap quickly (also because of the reduced ground clearance though...), but due the lack of precision in steering,
the lack of contact with the road surface,the fun of active driving gets spoiled, the cornering is somehow slack and the constant dancing around triggers strong knee to tank pressure
reflexes, something that I never have on the 1100...
If you line up behind the car at like 140kph after overtaking the one behind it, the air drag makes it very unstable and shaky, probably the price for the lower steering forces,
aerodynamic issues, etc...
Suspension:
hmm, you have to know that I have Wilbers in my 1100, so already firmer than OEM, but the 1300 is simply a pothole detector, the low self-damping of radial tires is one thing,
but in combination of the seat pressing in the crotch, it is very uncomfortable (if you then have to pee, the last 10km sneaking home got kinda painful ...),
the suspension of the 1100 swallows a lot more and still offers much more direct contact with the road , actually a paradox.
Braking:
After several "turtle kisses" I switched to using the footbrake as a main brake, the handbrake only as an "emergency anchor", the front brake always grips sudden and very hard;
Interestingly, it doesn't always have the same braking power: reach in before the left turn and have to push again that it decelerates appropriately, before the next right turn it
then suddenly bits you like I was in panic braking... never experienced such variations on the non-ABS or ABS-II/CBS ST1100 though...
So it could also be a lack of maintenance, badly vented, old oil inside or the like, it's a dealer's demonstration/rental probably not cared en detail...
Drive-train
there are even rougher noises from the drive, when coasting it rattles so hard there that it vibrates through to the seat; do not think that this is normal...
Well, guess I didn't pull out the checkbook, didn't I?
