Too late to help, but I found this process rather difficult and put this together. It is a combination of info from someone else (sorry, I could not find who wrote the original to give credit) and what I learned in doing it
LIGHT BULB REPLACEMENT
Right bulb - With the bike on the center stand, I turned the handlebars
to full lock RIGHT.
Check orientation of wires coming out of bulb holder from seated position. White and black seemed to come out to the right, green to the left, both at the top of the connector. This will help in aligning the bulb again. Do not pull the plug out
From the FRONT of the bike, reach in and pull the tab on the bottom of the boot firmly until it releases. Fully invert the boot as much as possible.
Push the retaining clip ?tab? towards the front of the bike and out away from the bulb and it should unclip the bulb. Rotate the retaining clip on the hinge out of the way
The bulb MAY be pulled right out or it may need to be rotated ? make a note of which way it needs to be rotated or remove the rotation reference here if it does not rotate
Note the relationship of the bottom tab of the rubber boot in reference to the bulb orientation as it may come off when pulling the bulb out of the connector. Install new bulb keeping the proper orientation, put back into headlight, make sure rubber boot is still inverted, swing retaining clip back in position and there should be a sortof click as it locks in place
Push rubber boot back into place, run a finger around the edge to make sure it gets fully seated
2) Then just push the retainer wire IN and UP (counter clock-wise). From
this angle, it's easy.
3) Remove old bulb.
4) Now (this can be the HARDEST part of this operation) push the retainer
wire out of the way and hope it STAYS there. Insert new bulb. This is
fairly easy (unless you're wrestling with the retainer wire too
. To
align properly to 'seat' the bulb, simply look into the front of the
headlight, and you clearly see where the 'dark' is, and move the bulb in the
direction of the 'dark' area in the center of the reflector. You will feel
it when it's right.
5) Swing retainer wire back to position, push IN and DOWN (clock-wise).
6) Replace boot. Plug it in. YOU'RE DONE. With one, that is.
Repeat the steps for the left bulb, using your RIGHT hand for that side, and
turning the handlebars full lock LEFT.
